Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Stand by light
A few months ago I replaced my lamp xl-2000u, it works fine, however recently my tv turns off to stand by mode every 22 minutes then turns back on after a minute and keeps repeating the cycle. I have checked and resecured the lamp to be sure it was secure but it does not seem to correct the problem. is there something else I can try before spending billions of dollars on a tv repair man?
thank you
  • 223 Answers
If this is happening I am sure the standby light should be flashing also. Count the flashes and the gap between them and its the error code for the fault. Consult handbook or sony forums for a solution. Hope this helps.
Posted on Sep 30, 2008
Samsung hlp4663 stand by light
I recently had this issue on my Samsung HL-R4667W. Did the new lamp (phillips) but it still wouldn't light up and was flashing the lamp light and then stanby. I started to remove the rear covers of the TV thinking maybe the wheel or ballast finally gave out. After removing the lower cover I noticed a wire hanging at a unusual angle from a circuit board. I touched it and it fell off. Traced the wire back to the main control board and found that it was a ground wire. I re-soldered it to the board and the TV fired right up. My other lamp was fine too. I hadn't moved the TV in 4 years and only once since I bought it in 2006 so I can't think of anything that would cause it to come loose short of bad soldering from the assembly line. That was a year ago and it works fine still.
Feb 10, 2014 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HL-R4266W 42 in won't turn on
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours).
Additionally, have you tried powering the unit using another outlet?
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
May 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lights
Nov 20, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
Tv turns off
the problem you are having is the lamp has gotten weak just replace the lamp and that will fix the problem the lamp part # is xl2100
May 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
HP Pavilion md5880n TV new lamp, left red light
I had the same problem the bulb was good but no power it was the transformer 975.00 under warranty from brandsmart. It worked for 90 days then the mother board went bad it cost 1000.00 they won't fix it .they gave me 1098.88 for a new one .Im gonig to sell mine for parts . I also have the stand for my tv also .
Jul 11, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Sony Vega KDF-E5OA10,picture will not come on, tv goes off.
There is a real good chance that the lamp fan is not turning. If you look with a flashlight in the vent on the left side looking at the rear of the set and have someone turn on the unit, see if it spins. if it doesnt, the protect circuit in the tv will not let the set turn on. Replacing the fan will cure the proplem if it is not turning.
Hope this helps,
Jun 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Picture cycles off and on
I replaced a burned out xl-2000u bulb with an after-market Philips bulb on my Sony KF60XBR800. After a fews weeks, I started experiencing intermittent black-outs with the "stand by" red light appearing. After a couple weeks it became intolerable. I then purchased an OEM Sony lamp and the problem has been gone for months. I read somewhere that the Sony circuitry monitors either resistance or watts and shuts the thing down for board protection. It was said that it is so sensitive it can can use only the Sony bulb. I'm a believer. If the bulb is going bad, i wouldn't doubt the protection circuit can kick in.
Nov 21, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
XL-2100U lamp cycles on and off
I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
Sep 10, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
I had the same issue. Replaced the lamp and now mine is working. Normally this is a sign that the bulb is out, however - I would say now that either:
1. Your lamp is defective.  2. The balast in your TV is defective.
I would check out - they can help.
May 18, 2008 | LG 52SX4D 52" HDTV
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
