Question about Maytag Dryers
How to instal new belt. - Maytag Dryers
  • francis rivero May 11, 2010
    it is just very tricky but i could guide you. what is the make of your dyer and how is it use?..is it top loading or front loading?
  • Maytag Master
  • 19,396 Answers
Remove the back panel, there you will find a tensioner, that will release the pulley.
Undo the belt routing and install the new one.
See here:
Maytag Dryer Belt Routing
belt routing for maytag performa ... -
Maytag gas dryer belt routing - FixYa
Posted on Sep 18, 2008
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Where is the tension pully on a 1993 ford taurus 3.0 motor
there is no spring tensioner on some of the 3.0 engines. See instructions below. I will paste a pic on the version that DOES have a tensioner at the bottom of this post.
3.0L Engine-Except SHO
ALTERNATOR BELT WITHOUT AUTOMATIC TENSIONER
  1. Loosen the adjusting arm and pivot bolts.
  2. Turn the alternator belt adjusting screw counterclockwise until the old belt can be removed.
  3. Remove the belt.
To install:
  1. Install the new belt over the pulleys. Check that all the V-grooves make proper contact with the pulleys.
  2. Adjust the belt tension, then tighten the adjusting arm and pivot bolts.
3.0L SHO Engine
ALTERNATOR BELT
See Figure 2
  1. Loosen the nut in the center of the idler pulley.
  2. Loosen the idler adjusting screw until the old belt can be removed, then remove the belt.
To install:
  1. Install the new belt over the pulleys in proper contact with the pulleys.
  2. Adjust the new belt to specifications as follows: Turn the idler pulley nut to the right to tighten the belt to a specification of 220-265 lbs. (980-1180 N). Torque the idler pulley nut to 25-37 ft. lbs. (34-50 Nm).
POWER STEERING AND AIR CONDITIONING BELT
See Figure 2
  1. Remove the alternator belt.
  2. Loosen the nut on the tensioner pulley.
  3. Turn the belt adjusting screw on the tensioner counterclockwise until the belt can be removed, then remove the belt.
To install:
  1. Position the new belt over the proper pulleys, making sure the V-grooves are properly seated.
  2. Install the alternator belt.
  3. Adjust the power steering and air conditioning belt to a specification of 154-198 lbs. (690-980 N) with a belt tension gauge.
  4. Adjust the alternator belt.
3.0L Engine (Except SHO) and 3.8L Engine
VEHICLES THROUGH 1993 WITH AUTOMATIC TENSIONER
See Figures 4 and 5
  1. Insert a 1 / 2 in. breaker bar into the square hole in the tensioner.
On the 3.8L engine, the tensioner has a1/2in. square hole cast into the rear of the tension arm directly behind the pulley. On the 3.0L engine, the1/2in. square hole is cast into the spring housing on the front of the tensioner.
  1. Rotate the tensioner clockwise and remove the belt.
Fig. Fig. 5: 3.8L belt schematic-1993 shown
To install:
  1. Install the drive belt over all the pulleys, except for the alternator pulley on the 3.0L engine for vehicles through 1992, or the idler pulley for 1993 3.0L vehicles.
  2. Rotate tensioner counterclockwise and install the belt over the alternator pulley. Make sure that all the V-grooves make proper contact with the pulleys.
  3. On the 3.0L engine, install the alternator belt for vehicles through 1992.
  4. For 1993 3.0L vehicles, install the drive belt over the idler pulley.
Oct 01, 2010 | 1993 Ford Taurus
Retractable seat belt wont close
Is this a NEW seat belt?  Or a junkyard part... Per the Toyota 1988 Repair Manual - the belt is allowed to be pulled out at a tile of 15 degrees or less; and cannot be pulled out at over 45 degrees of tilt.
Your problem is the belt is not retracting.  The manual states to replace the assembly.  It also states: "Whenver installing a new belt assembly, verify proper operation before installation."
If a new part does not have proper operation; have it replaced. If this is a 'used'  new part - get a NEW seat belt.
Apr 07, 2009 | 1988 Toyota Camry
Install seat belt through seat belt guide 1990 camaro
The new seat belt guides will have a **** in them that allows you to put the belt through it. If it's a used guide taken off another car it may not have the ****.
Mar 16, 2009 | 1990 Chevrolet Camaro
What tools do I need to remove both engine belts from my wife's 2004 Concorde.do I need ome special tensioner tool to move the tensioner the other belt is a regular v belt and it goes around the...
2.7L & 3.5L Engines same Tools & Procedure Rate Me Please 1/2 in. breaker bar & Special Tool 7198 for conventional V-belts and Poly-V belts
  1. REMOVAL
    NOTE: The A/C drive belt self tensioner is NOT a dynamic tensioner. After adjustment the tensioner bracket bolts are tightened. The torsion spring is no longer responsible for tensioning the A/C belt. The torsion spring is only used for initial belt tensioning.
    1. Remove generator/power steering belt to gain access to A/C belt. Refer to GENERATOR/POWER STEERING BELT for procedure.
    1. Loosen BUT DO NOT REMOVE tensioner locking bolt and pivot bolt (Fig. 2).
    2. Insert 1/2" drive breaker bar into square opening on belt tensioner. Rotate tensioner counterclockwise until belt can be removed from pulleys (Fig. 2).
    3. Slowly rotate tensioner clockwise to relieve spring load.
    CLEANING
    Clean all foreign debris from belt pulley grooves. The belt pulleys must be free of oil, grease, and coolants before installing the drive belt.
    INSPECTION
    Belt replacement under any or all of the following conditions is required:
    • Excessive wear
    • Frayed cords
    • Severe glazing
  • Poly-V Belt system may develop minor cracks across the ribbed side (due to reverse bending). These minor cracks are considered normal and acceptable. Parallel cracks are not (Fig. 3).
    NOTE:
    Do not use any type of belt dressing or restorer on Poly-V Belts. INSTALLATION
    AIR CONDITIONING BELT - NEW
    WARNING: DO NOT REMOVE A/C BELT TENSIONER LOCKING BOLT WITHOUT FIRST HOLDING THE TENSIONER WITH A 1/2" DRIVE BREAKER BAR, AS PERSONAL INJURY COULD RESULT.
NOTE: Verify that torsion spring position is in the new belt position before installing a NEW belt (Fig. 4). If torsion spring is not in the new belt position, follow steps 1-7 to change the tensioner spring from the USED belt position to the NEW belt position.
  1. Insert a 1/2" drive breaker bar into the square opening on the tensioner. Hold counterclockwise pressure on tensioner while removing the locking bolt (Fig. 2).
  2. Carefully release spring load of the torsion spring on the tensioner.
  3. Remove pivot bolt, tensioner, and spring from front timing cover.
  4. Insert spring arm into the NEW belt position on the tensioner (Fig. 4).
  5. Install torsion spring, tensioner, and pivot bolt.
  6. Install pivot bolt. Tighten only finger tight, at this time.
  7. Using a 1/2" drive breaker bar, apply counterclockwise pressure until locking bolt can be installed.
    1. Install the NEW belt by rotating the tensioner counterclockwise until the NEW belt can be installed on pulleys. See (Fig. 5) for belt routing.
    2. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    3. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    4. Install generator/power steering belt.
    AIR CONDITIONING BELT - USED
    NOTE: A "used belt" is considered having more than 500 miles of service use. NOTE: Perform steps 1-7 to change the tensioner spring from the NEW belt position, to the USED belt position.
    1. Insert a 1/2" drive breaker bar into the square opening on tensioner. Hold counterclockwise pressure on tensioner, while removing tensioner locking bolt (Fig. 2).
    2. Carefully release the tension of spring on tensioner.
    3. Remove pivot bolt, tensioner, and spring from front cover.
    4. Insert spring into the USED belt position on tensioner bracket (Fig. 4).
    5. Install spring, tensioner bracket, and pivot bolt.
    8. Install the USED belt by rotating tensioner counterclockwise until belt can be installed on pulleys. See (Fig. 5) for belt routing.
    9. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    10. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    11. Install generator/power steering belt.
I Hope This is Of Help To YOU IF So PLEASE HELP ME RATE ME it Helps Thank You Very Much and Happy Motoring !!!!!!!!
Jan 21, 2009 | Chrysler Concorde Cars & Trucks
Installing new serpentine belt
i would put a new belt on and when your done try to twist the belt if it twists more than half of the way the tesioner is worn out if it was me i would probally replace it just to be safe because it is a 93 and a turbo d which has more vibration which can wear out the spring
Dec 20, 2008 | 1993 Ford F250
Hoover very noisy after new belt installed.
what is the belt # you have installed (generic)? Yes, there are problems with using generic belts on Hoover Vacuums. If you have noise I would suspect the roller, and replace it. the cost is about $25 and is something that you can install. The newer type are mande of wood and are very quiet.
Nov 23, 2008 | Hoover U5753-900 WindTunnel Bagless...
Dryers Logo
765 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
