Question about Frigidaire ATF6000ES Front Load Washer
Looks like the drum has droped
It looks like the drum has droped down about an 1/2 inch makes a loud shaking noise, springs are not broke !
  • Anonymous Sep 22, 2008
    The drum has dropped and causing banging noises.
    President:
  • 2,712 Answers
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Sep 28, 2008
Whirlpool dryer leq8611lw0 shakes violently and makes loud noise
Something must be inside the blower wheel. I cannot imagine why it would shake like that. This dryer has 4 wheels instead of 2 so it oughta be stable. The only thing to do is get inside the machine and see what is causing it. The dryer with a filter inside is also sometimes known as a series 90 dryer. Look for some series 90 dryer videos on youtube. Like this crappy one I made:
Apr 22, 2014 | Dryers
Amana top loader washing maching permanently tilted drum & loud banging during spin cycle
I guess you washed some curtains and blankets in it that it spun unbalanced. There are 2 things. One is the one of the suspension springs broke off. Another is the center post is already bent. You may have to check inside. If you are handy, you can take off the cover and check. Suspension springs are dangerous when being replaced. You may have to wear a pair of goggles. With the centerpost, it is difficult to replace. I suggest you call a technician for this.
Jan 17, 2014 | Washing Machines
WWA5600SBLWW loud noise like a belt broke
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 23, 2013 | Washing Machines
Small spring is hanging red clip on floor tub dose not look level water coming out around sides an top when it spins
this is one of several drum balancing spring clips and it broke or popped-off. This will for sure make the spin cycle shake the drum very much and spill water. Nedd to open the machine housing and replace/repair the spring.
Nov 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Baldwin Model 230 DE when turned on makes a loud thunk like the volume is turned way up, then when you disturb or shake the organ or stomp on the floor it makes a loud noise like if you twanged a coil...
If the organ has a reverb spring "tank" in it, that is likely where the spring sound comes from.
The initial noise is likely due to the initial unbalance of the power audio amp.
Lesser organs don't disconnect the speakers till the amps attain balance so the inrush pulses the speakers..
Mar 10, 2010 | Michael Kelly Music
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Loud knocking noice around drum area when on final spin.
i suspect the bearings have gone
hope this has helped :)
Oct 14, 2009 | Washing Machines
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
417 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
