Question about Dynex 802.11g Wireless-G Laptop Card
CONNECTION I HAVE A CARD BUT WHEN I TRY TO CONNECT IT SAYS IT IS CONNECTED BUT I HAVE A GREEN AND A YELLOW LIGHT ON THE CARD
  • hanible Sep 18, 2008
    THE LIGHTS ON THE CARD, ONE IS GREEN AND THE OTHER IS YELLOW . I HAVE VERIZON DSL, I HAVE CALLED THEM AND I WAS TOLD THAT ITS THE DYNEX CARD AND I SHOULD CONTACT THEM
  • ariel santos
    ariel santos May 11, 2010
    try first to connect to the internet
  • 446 Answers
It means that the card is still inactive, it could be from the card itself or your setup
Posted on Oct 11, 2008
Why does the data light keep flashing when device is on and it won't connect to pc
Are you using the correct cable to connect?
Has the camera ever connected to your computer correctly? If not, it may be that your computer isn't recognising the camera.
Try removing the card from the camera. If your computer has an inbuilt card reader, try using that. Or get a usb card reader.
Feb 17, 2016 | Cameras
Rs125 seatalk to st6000+
An RS125 can be connected to a ST6000+ with either NMEA or SeaTalk data connection. NMEA is easier IMO.
To connect via NMEA, the RS125 red wire would go to vessels +12 volts. Yellow would be connected to the NMEA+ on the back of the ST6000+ and the shield, green and brown would be connected to the NMEA - on the back of the ST6000+ display
When connecting your RS125 into an existing SeaTalk network it should be powered from the network and not the display. The red and green of the 125 connect to the course computer SeaTalk red. The yellow cable should be connected to your display SeaTalk yellow. Shield and brown of 125 should be connected to SeaTalk gray.
Page 4 and 5 of the RS125 manual have pictures. PDF File
Regards
Feb 22, 2012 | Boating
DEAR SIR/MADAM TO WHO IT MAY CONCERN I HAVE A LINKSYS WAG325N ROUTER , I did REST IT ALREADY i GOT THE POWER LIGHT GREEN THE DSL GREEN THE WIRELESS GREEN BUT THE LOCK (SECURITY) IS YELLOW/ORANGE AM...
connect direct to the router using a cable connection then try accessing the routers setup page again you must be connected before you can access.. also i noticed its a "N" type router and if your pc doesnt have the drivers for an N router then its sure to cause problems..
Feb 12, 2011 | Linksys Wireless-G WRT54G Router
Dell dimension 3000 showing the following LEDS on the back a-green, b-yellow, c-yellow, d-yellow, won't boot up.
if the Dell logo does not appear at all when you start the computer, unplug its power cord, press its power button for say 10 seconds to clear any power left to it. Next, try to disconnect all external devices connected to it, then remove the power and ide/sata cables to your hard drive and/or CD/DVD drives, remove all the memory and just reconnect 1 confimed working memory to the first memor slot. Remove any other cards like video card, or network cards, then remove and reconnect the power connection from the power supply to the motherboard. Reconnect the power cable and attempt to turn it on. If the back panel light code changes, try to re-connect the devices starting from the memory, then expansion cards and the storage devices one by one. After connecting each card or device, test the system to see which device may be at fault. If nothing changes, could be your power supply or mainboard and you may need to get the replacement for them. HOpe this lead you to the right direction in getting this solved. feel free to rate how helpful this information is. Thanks
Oct 14, 2010 | Dell Dimension 3000 PC Desktop
Since I've connected my Belkin Play router for my Toshiba laptop, both my laptop and PC are now displaying "unable to connect to webpage. My laptop works better when I've an ethernet cable attached but I'd...
Hi ok I'm here and your problem will be fix.
If you are talking about wireless....
  1. many customers have a problems with Toshiba laptop that no means Toshiba Laptop is not Compatible with Belkin,the first think we need to do is to know what happen with your configuration.
  2. Windows XP?Vista?w7?Mac? so many questions
  3. Ok actually windows make any time security package update that make also a problems with connectivity.
  4. ok also firewall and anti virus lock the signal is we are talking wireless
  5. Now if even using cable trough router you still haven't connection means maybe there's not connection
  6. so we need to know what is the status of the light in your your router Green Yellow or Red
  7. Green there is a connection
  8. Yellow only laptop and router re connecting
  9. Red both are not connected
  10. if we talk about number (8) you mas need to clone first your mac address to get connected
  11. if the light is RED reset your router and after power cycle modem and router let 3 minutes and check if light turn Green.means connected
any questions for more explanation just ask me for a remote your PC
Sep 17, 2010 | Belkin Wireless Play Router (F7D4302)
Is the smaller light onto of the router (just below the larger green light) supposed to stay on when connected and if so, is it supposed to be green? Have seen it in yellow and red but it is not staying...
The second light is for your wi-fi protected setup. If it solid green then you have a secure connection. Blinking means looking for device. Amber means a connection was not connected. Off means idle.
Source: www.belkin.com
Aug 22, 2010 | Belkin Wireless Surf Router (F7D2301)
I am using windows XP, when i insert a network connection on the NIC port, the right NIC light blinks yellow instead of Green, repeatedly a message says a new hardware is detected and fails to install. i...
The yellow light means that it's not connected with a compatible driver to the computer or it is not connecting to your network for some reason.
Green, means everything is, ok.
I've encountered this before on some off brand network adapters, and tried other ones, and that was the only way I could make it work...
in an unknown system.
However, since you say that yours worked before... that tells me that you think it should work, again. But, something could have changed in your network.
Are there any other components on your network, like a switch that could have gone bad, or bad wiring?
Jul 28, 2010 | Dell Ethernet Card Network Adapter
Modem is not recognized
do you have the driver for the modem installed on that pc.it has to be check your device manager see if there any question marks in yellow or quotation marks if so itll be the driver needed
Jun 21, 2009 | Gateway Profile 4 All In One (MPN...
Dell c521 won't start
- disconnect the hdd and optical drive cables, remove the expansion card, reseat the atx and 12v cable and turn the computer on. if the power led is glowing green connect the devices on by to find what device is causing the no post issue. after the strip down if the power button is still yellow replace the motherboard
Dec 06, 2008 | Dell Dimension C521 PC Desktop
Remote Control Repair
Open up your controller and look for 4 Wire! Green, light green, blue and yellow! Green and yellow is for power i guest! Light green and blue is for bass. 4 together max everything!
Dec 01, 2008 | Audio Players & Recorders
Dynex 802.11g Wireless-G Laptop Card Logo
88 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
