Question about Mitsubishi WS-55807 TV
No Power TV does not power-up. No green light, nothing. The main fuse is okay.
  • 927 Answers
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH....... sory if was tooooo loooong
Posted on Sep 25, 2008
Replaced the power supply TV was completely dead no blinking nothing replaced the power supply got green steady light but no sound or picture just green light fans TV stays on until i shut it off remo
ReCheck the connections.if the original power supply burnt out due to a short or system failure then you will need to check all the module boards for any evidence of burning.check the capacitors for signs of swelling or splits as these are usually the cause of no life.also I assume the power supply was the right volt/ amp as this May have blown an on board fuse on the main pcb.
Jan 11, 2015 | Pioneer PureVision Pro-1410HD 61 in....
My green light does not come on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_15_2012_1_33_36_pm.jpg
May 15, 2012 | Westinghouse W33001 30 in. HD-Ready LCD...
THE TV WILL NOT POWER UP
It depends on a lot of other things, but you could try these steps . . .(assuming its a TFT flat screen)
Has the mains fuse blown ? try a different mains cable.
If it works from a power supply/mains transformer (a small box attached to the mains supply cable), check that box - they usually have a small green light on them to show they are getting power. These are easily replaced if that part is faulty.
Has the power cable come detached from the rear of the TV ?
Does a power light appear on the actual TV front (usually blue or green), and then go red (or off) after a few seconds. In that case the screen has a more hard to fix problem inside :(
Apr 04, 2010 | Sylvania LD370SS8 37 in. LCD Television
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
Sound but not picture - capacitors look okay, hair dryer didn't w
if you feel the power supply is good then the next item would be the main pcb. if the back light is coming on with no video then the t-con board is bad but power supply seems to be most common for me.
Jan 06, 2009 | Insignia IS-LCDTV32 32 in. Television
Broken TV
Replace the y-main board and the upper and lower buffer boards. 300.00 from Sanyo. Install them your self or get someone technically minded to do it for you. It worked for me. It's been 6 months and the t.v. is still going strong.
Jan 04, 2009 | Televison & Video
No Power
does the front green led light flash?
unplug the set for 30 min then replug try to turn on. if the light does not flash then i might be a main fuse. Point... main fuse falure ussally means more than just fuse. if the light flashes then you have a shutdown condition. This set processor shuts it down for 1 or 25 different reasons as technicians we have a computer that reads errors much like a cars error codes.
Nov 02, 2008 | RCA HD52W59 HDTV Projection Television
LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Nov 28, 2007 | Televison & Video
Mitsubishi WS-55807 TV Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
