Question about Microsoft Windows XP Professional for PC
Word I moved from one machine to another (from XP to Vista) and I need to know how to install my old on Vista. I simply cannot see where the "Templates" file is located and how to make if visible. I would appreciate any guidance. Bill []
  • Tim Babcock
    Tim Babcock May 11, 2010
    Curious, what is
    Problem Solver:
  • 11 Answers
On your old machine do the following:
1. Double click on My Computer.
2. Click on the Tools menu in the top menu bar.
3. Click on Folder Options...
4. Click on the View Tab
5. Click on the little button next to "Show hidden files and folders"
6. Click OK.
7. Double click on Local Disk (C:)
8. Double click on the Documents and Settings folder
9. Double click on the folder with your user name
10. Double click on Application Data. (That folder will be dimmed)
11. Double click on the Microsoft folder.
12. Double click on the Templates folder.
13. Copy the file to a USB drive or email it to your self.
14. On the new computer, Go to the same directory and replace the file there wit hthe one you copied from the old computer.
hope this helps!
Posted on Sep 22, 2008
I don't understand why I have just started getting "Insufficient Memory" errors when I startup MP Navigator 3.0 I have tried downloading the latest driver for Vista but no change. Any...
There are a couple of things that can cause this. One is a corrupted template, one is a corrupted printer driver, and the other would be some sort of third party add-ins. So let's start with the simplest to try and that is replacing the template.
Click on Start, go to Search, and in the Search box type There should be a search option that you can check for 'search hidden files', make sure that is checked. If it does not find it, try searching for *.dot. It may be hard to find because it is a hidden file. You may have to go into folder options and be sure "show hidden files" is checked. Whenever you find, rename it and restart your computer. Open Word and it will create a new template, which is what Word uses as a default blank document.
If that does not work, read this article about a third party add-in that can cause this issue:
Let us know how that works out and if you need additional help
Feb 20, 2011 | Computers & Internet
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Nov 03, 2009 | HP Business Notebook 550
Word 2007 saves and closes normal.dotm everytime I close it. It doesn't ask for anything, but it shows as an opened document in Word and start menus list.
It could mean that the file is corrupt.
Try this:
1. Do a search for
2. when found, change the name to ""
3. restart your machine
Good Luck !!!!!!
Jul 21, 2009 | Microsoft Office Professional 2007 Full...
Microsoft word 2000 is not responding
Use the Search Option, selecting all files (search hidden as well), to locate the file named Once found delete or rename the file Normal.OLD. This is the template that Word uses for all documents. It not uncommon for this file to become corrupted and cause problems.
After finding this file in your computer, rename it to something else like Normal.Old or delete it completely and then retry opening word. Word should automatically recreate the template for you. If it works properly after renaming the template file, you can delete the old one since a new one will have already been created. may be hidden so you may have to go into your Window Explorer options and change them to show hidden files and folders before doing your search
To enable viewing of hidden folders:
Hope this information has been helpful.
Apr 30, 2009 | Microsoft Office Professional 2007 Full...
Office XP Pro
The "Normal" template opens whenever you start Word, and it includes the default settings for your new documents... as well as any customizations you may have opted for along the way. Sounds like your version of the normal template now includes the text of this document.
On the File menu, click Open, and then navigate to C:\Documents and Settings\user name\Application Data\Microsoft\Templates and look for "". You may need to change the Files of Type drop box to "Document Templates" to see it.
Open the file, select all the text you see there and delete it. Save the file and close it. You should get clean pages now when you open a new document.
Alternatively, you can use Windows Explorer to navigate to that same directory and delete the entire file. MS Office will simply create a fresh one when you launch Word again.
Hope that helps!
Good luck.
Sep 09, 2008 | Microsoft Office XP Professional OEM w/...
While installing xp in vista machine no hard disk found
this is because you cannot downgrade from vista to xp on the machine in which vista has been preloaded
May 27, 2008 | Microsoft Windows 2000 Professional for PC
How to uninstall Vista and load XP in Lenovo Y510 Ideapad
Several points:
1. Although you may prefer XP to Vista, it is probable that you are simply
more familiar with it. If you would give yourself some time to become
accustomed to Vista, you might find that you like it. I know I do.
2. You can't literally "uninstall" Vista, but if you want XP instead, you
simply do a clean installation of XP the normal way. That will format the
drive, removing whatever is on it.
3. Do you already have a copy of XP you want to install? Did it come with
your old computer? If so you need to be aware that OEM versions (such as
those that came preinstalled on computers) are permanently tied by their
license to the first computer they are installed on. If that's your
situation, your copy of XP is not available to be used on your new laptop.
4. Over and above the licensing issue in point 3, many OEM version of
Windows XP are BIOS-locked to the computer they came with, and you actually
won't be able to install it on a different one.
5. You should check with your vendor to be sure, but the warranty on your
new computer may be voided if you change operating systems.
6. Laptops often have special drivers they need for components within them.
Your new laptop undoubtedly came with all the drivers needed for Vista, but
it didn't come with the drivers needed for Windows XP. Finding and getting
the drivers you need may be a problem.
If I were in your shoes, I'd stick with Vista.
If you still want to uninstall:
The normal way to "uninstall" any operating system is to format
the hard drive and install a new OS of your choice.
After backing up any data you wish to transfer to the new OS
installation, simply boot from the WinXP Home installation CD. You'll
be offered the opportunity to delete, create, and format partitions as
part of the installation process. (You may need to re-arrange the order
of boot devices in the PC's BIOS to boot from the CD.)
HOW TO Install Windows XP;en-us;316941
Then the backed up data can be restored and applications re-installed.
You can even try a dual boot, where you have both Vista and XP on the same system. Click HERE for pictorial guide.
May 23, 2008 | Computers & Internet
Normal hard disk connection
what does the xp setup say? no harddrive found?
you need to have the cd in your drive during startup and make sure your pc is set to start up from cd.
check it in the bios.
let me know if you need more assistance or more detailed assistance.
May 09, 2008 | Intel D945GTP Motherboard
Copying Microsoft Word macros to new computer system
Macros are stored in one of two places, Irene - and you decide where and when you create one. When you select Tools -> Macro -> Record New Macro you’re prompted to either create the macro in the global template ( file, or the document you’re currently working on - by default, is selected so that the macros are available in all documents you create.
Your file is also where all custom styles, toolbars and autotext entries are stored, and it’s possible to transfer all of these - plus your macros - from one machine to another courtesy of Word’s Macro Organizer tool. The walkthrough below explains how to access it and back up your macros to a file you then transfer to your second PC before copying those macros into the file on that computer so the macros are accessible from there too.
While this tool is the best way to transfer macros, or other individual elements of your file (just select the appropriate tab to transfer styles, toolbars and autotext entries in exactly the same way), if you’re migrating to another PC you may wish to take all your settings with you. If you have Office 2000 or later you can use the Save My Settings Wizard to back up all your Office customisations - including the template - and then use the same wizard on your new computer to restore them to the version of Office installed there.
Office XP and 2003 users will find the tool installed with Office -access it from the Microsoft Office Tools menu on the Start -> All Programs menu; Office 2000 users need to download it from here. It’s called the Microsoft Office 2000 Profile Wizard here.
Nov 03, 2007 | Compaq Presario 5000 PC Desktop
Microsoft Windows XP Professional for PC Logo
127 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
