Question about Casio Exilim EX-Z57 Digital Camera
Nintendo dsi error 52211 - Casio Exilim EX-Z57 Digital Camera
Error code 206602
from nintendo : Error Code: 206602
Nintendo DSi Shop - Nintendo Points Card
There appears to be a problem using the Nintendo Points Card.
  • Make sure you are entering the number in the correct field in the Nintendo DSi Shop.
    • For Nintendo Points Card redemption, enter the number off the Nintendo Points Card in the "Add Nintendo DSi Points" section off of the main Nintendo DSi Shop page, and select "Redeem Nintendo Points Card."
    • If you are attempting to add points with a Visa or MasterCard, enter your card information in the "Add Nintendo DSi Points" section off of the main Nintendo DSi Shop page, and select "Buy Nintendo DSi Points with a Credit Card."
If that does not work, please call 1-800-255-3700 so that we can assist you further
Jan 22, 2014 | Nintendo DSi XL Burgundy
Error code 204970'
FROM THE SUPPORT WEBSITE......FOUND HERE
Nintendo DSi Shop Errors - Network ErrorThere was an issue with your connection to the Nintendo DSi Shop. Please try the following:
  1. Go into the Nintendo DSi menu (Wrench icon on the main menu screen.
  2. Select "Internet," and "Connection Settings."
  3. Erase your existing Internet Connection Settings and set up a new connection.
  4. Once you have established and tested a successful connection test, try the connection to the Nintendo DSi Shop again.
If you have verified that your Nintendo DSi or Nintendo DSi XL system's internet connection is working, then there could be a temporary issue with the Nintendo DSi Shop. Please wait awhile and try your connection again.
I hope this helps :D
Dec 03, 2011 | Nintendo DSi Black Console
Error code 299001
Here's what Nintendo has to say about this code:
Error Code: 299001 Nintendo DSi Shop
There appears to be a temporary issue with the Nintendo DSi Shop. Please wait awhile and try your connection again later.
If you have waited several hours but are still receiving this error code, please call 1-800-255-3700 for assistance.
In short, there's nothing necessarily wrong with your DSi, but if you get it repeatedly I suggest you call that number.
May 19, 2011 | Nintendo DSi Black Console
Nintendo DSi reads. "An error
Does this error occur when you play a certain game or all games? Or maybe it comes up when you first turn on the DSI? More details are always helpful, however, you can try some of the following tips to see if you can resolve the error.
-Try removing the battery for a couple of minutes then replacing it.
-If this is caused by just one of your games, then that game is most likely damaged.
-If possible, install the latest firmware to your DSI which may resolve the issue.
-Your DSI may still be under warranty support, and I would recommend contacting Nintendo for repairs. Phone 1-800-255-3700
Regards,
G33k
May 11, 2011 | Nintendo Video Game Consoles & Games
Error code 051099"1 nintendo dsi.trying to get
Error Code: 051099Was this information helpful?
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
Here's a link:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
DONT FORGET TO RATE THIS PLEASE
Jan 30, 2011 | Nintendo DSi Matte Blue Console
I-have-2-nintendo-dsi-consoles-and-one-nintendo-dslite-console-and-I-have-some-new-games-that-I-can-use-in-the-dslite-but-no-in-the-dsi-consoles.The-dsi-consoles-gave-me-an-error-message
Hi marissacruz,
If the game works in either a Nintendo DS or Nintendo DS Lite but not on your DSi console, it means that your new game is likely a counterfeit product.
However, you did mention that it gives you an error. I have attached a link that you can use to get a possible solution for the error that you are having. Just enter the error code on the top left half corner of the screen and select DSi as the console. http://www.nintendo.com/consumer/systems/dsi/en_na/trouble_messages.jsp
All the best to you. Hope to hear positive results.
Dec 25, 2010 | Nintendo DS Lite Console
My wii keeps saying error code: 204969
Error Code: 204969 Nintendo DSi Shop Errors - Network ErrorThere was an issue with your connection to the Nintendo DSi Shop. Please try the following:
If you have verified that your Nintendo DSi or Nintendo DSi XL system's internet connection is working, then there could be a temporary issue with the Nintendo DSi Shop. Please wait awhile and your connection again.
If you have tried the above troubleshooting and are still receiving this error code, please call us 1-800-255-3700 so that we may assist you further.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=204969&system=DS&locale=en_US&action2.x=21&action2.y=33
Nov 23, 2010 | Nintendo Wii Console
DSI WILL NOT CONNECT TO WIFI ERROR CODE 051099-1
Error Code: 051099 This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
Dec 26, 2009 | Nintendo DSi Black Console
Dsi error code 201022 when i tried downloading stuf it dosent work it says error like right at the end
Error Code: 201022 Nintendo DSi Shop There are appears to be a temporary problem with the Nintendo DSi Shop.
  • Nintendo DSi Shop may be temporarily down (this could include scheduled maintenance). Please wait a few hours and retry the connection again.
Oct 18, 2009 | Nintendo DSi Black Console
Casio Exilim EX-Z57 Digital Camera Logo
178 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
