Question about Durabrand Portable DVD
Motor does not turn on
My 9' Durabrand portable just stopped working. The on light does turn on when plugged in but the motor does not seem to start.
Does anyone know what to do? Ingrid
  • 171 Answers
I could walk you through a list of tests, but the truth is the unit will need service. The good news is, you can now contact Durabrand and get the tests directly from their website and contact them for warrantyservice. Please click on the link below:
Durabrand Technical Support, Parts and Accessories
http://1800customersupport.com/
If you require any additional assistance do not hesitate to click on the "ASK ME" button and I will respond to your request as soon sa I can.
Posted on Oct 09, 2008
Missing DC 9 volt cord for durabrand 1700 dvd portable player
you make new 9 volt charger purchase new changing pin compatible 1700 dvd player and operate it
May 20, 2012 | Durabrand DUR-1700 Portable DVD Player
DVD says loading.... but keeps turning, stops, turns, stops
It is a problem with the laser. Getting a lens cleaner could help, but it is doubtful. Your best bet, tap the unit while the disk is trying to load.
There is a motor that moves the laser into place. Often the motor burns out or it does not focus correctly after a while. Sometimes, they just get stuck. A tap may kick start the motor into place if it is stuck. Most likely, you will have to replace the unit.
P.S. Toothpaste and electronics don't mix. CD players get extremely hot. You will eventually be cleaning Crest out of your DVD player.
Jul 25, 2009 | Durabrand PDV-705 Portable DVD Player
I need chargers for PDB-702 and PDV-709. Durabrand 7' portable DVD player and Durabrand 9'' portable DVD player.
The following link is to amazon.com where you can purchase (1) Durabrand charger that will work with both of those models. Great price and secure shopping.
http://www.amazon.com/Durabrand-DPX3290L-DUR-1500-DUR-1700-PDV-708U/dp/B001R2253A/ref=sr_1_1?ie=UTF8&s=electronics&qid=1247696448&sr=8-1
Hope this is exactly what you needed, post back if you need any further assistance. Thank you for choosing Fixya!
Jul 15, 2009 | Ultra Televison & Video
Scooter motor does not operate
are you sure its in gear. I had the same problem and I pushed the nob on top of the motor towards the front of the machine and it worked!!!
Apr 03, 2009 | Health & Beauty
Durabrand portable dvd player motor spin but disk not playing
I have the same problem, the this dvd player i use one time
Nov 17, 2008 | Durabrand DUR7 Portable DVD Player
Need code for durabrand portable dvd player
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Durabrand PDV 705 problem
It seems obvious that you have a bad battery. You'll need to find a replacement.
Geno
Mar 04, 2008 | Durabrand PDV-705 Portable DVD Player
Durabrand Dur 7 dvd player
simply take the unit to Radio Shack and ask the peeps there to hook you up. They have almost any type of plug for almost any type of adapter. Good Luck
Jun 20, 2007 | Durabrand DUR7 Portable DVD Player
Cant run original DVD's
open tray hit stop then press3597 chance your code for 9 or 0 then close it ll be multi region
Mar 01, 2007 | Durabrand DUR7 Portable DVD Player
Durabrand Portable DVD Logo
50 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
