Question about GE WCVH6260F Front Load Washer
Says Door is locked but isn't
With one minute left in the cycle the door popped open but display says door is locked. If I push the button inside it makes noise like it is going through the motions but does nothing.
Repair was just here yesterday for a leak and all he said was we are using too much soap because it is environmentally friendly and suds's more to make up for the lack of enzymes to clean. He only did a diagnostic.
All seems strange timing.
I went to appliancepartspros.com. and there was my problem word for word. I then called the GE repair man who came a day earlier and did nothing for us. He'll be back on Monday to fix the problem that I solved for him.
Posted on Sep 19, 2008
Mazda 1996 lx prestige passenger door lock dose not work ether with key button our buy pushING down on
Need to take inside door panel off and look at inside door latch. The locking rod probably broke at door latch. Or it lucky unhooked. To find whice rod it is. You may need to cut hole in platinum sheet near door latch. Then move one left to right. One will lock it and one will open door. Then check to make sure both ends are connected on the lock rod. Almost sure it is the small plastic piece broken of door latch. And when taking inner door panel off. Make sure all screws are out. And use flat screw driver next to plastic tabs to pop them out. If careful everything will go back together easy.
Jul 11, 2016 | Mazda Cars & Trucks
The door no longer pops open when the latch button is pushed. How do I fix this?
One of the door latch arms or the latching mechanism inside the oven have broken. you may have to buy a complete door lock / latching assembly . Might not be worth it. Check with your nearest parts supplier.
Apr 09, 2015 | Emerson Microwave Ovens
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
My LG washer is stuck and won't drain so I can't open the door to fix the problem which I suspect is it is overloaded. What do I do?
Hi
Turn OFF the main power supply to the machine .After 7 minutes the door will get unlocked irrespective of level of water in the tub. As long the power is going to the machine the lock will not open.
Regards
Berry
Feb 07, 2010 | LG WM-2277HW Front Load Washer
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
My Frigidaire front load washer won't start
A year later! I experienced the same problem this morning - exactly as you, Bessie24, stated. I could hear a faint humming sound and thought the lock mechanism was still trying to complete its locking function. It would know the lock function was completed when the lock trips the wee (micro) switch. I reckoned if the female portion (with switch) were a tiny bit loose, the switch might not trip, so I loosened then tightened the two screws attaching it to the carcass of the washer (as opposed to the door part) while pushing upward on the same part. This fixed my problem and i hope many others find this procedure useful.
Sep 09, 2008 | Frigidaire GLTR1670A Front Load Washer
Self cleaning oven will not start for cleaning door lock problem
hi alot of people have been having this same problem with either the door locking before clean cycle and not opening or it goes through clean cycle and then the door is stuck shut and wont open.
You could try this it sometimes works before you press start push the door shut and keep pressure on it i mean lean on the door so your pushing it shut further than it is now then whilst putting pressure on the door try pressing start button again if it then starts cleaning cycle keep pushing door for about a minute then gently let go of the door.
This should then allow it to go through clean cycle but remember when clean cycle has finished dont try opening the door strait away as you will then have the problem door stuck and wont open you need to let the oven cool down before the door will open.
If after pushing the door shut a bit further you still have problem then the only thing you can try is switching off at mains for 24 hours this should release the lock let me know how you get on ok
Feb 10, 2008 | Frigidaire FGFB75D Gas Kitchen Range
GE WCVH6260F Front Load Washer Logo
56 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
