Question about Lexmark Office Equipment & Supplies
I have a Lexmark x1195 printer it copy the test page but don't want to copy from the computer .it seem like it's copying but paper come out white
I have a lexmark 1200series it will prints test page but will not page i wont print
Posted on Sep 18, 2008
I want to test printer with no conection to the PC only test page. What buttons Can I press for to print test page directly of printer?
Hi, you can't print a test page directly from the printer, but since it's a copier also, you can copy a page of text or graphics to make sure everything prints okay. Just place a piece of paper on the glass and press either the black or color copy button. (The computer must be on to make a copy.)
Sep 26, 2010 | Lexmark P3150 All-In-One InkJet Printer
Lexmark X1195 seems not to work on Windows Vista; I've tried just about everything;CD software, download driver from lexmark and it still does not print!
Hi. Try uninstalling the Lexmark
software for a fresh start. To
uninstall it properly, go to Start
Menu > Programs > Lexmark folder > Uninstall. Reboot pc. Check if your computer is running on 32-bit or 64-bit operating system by going to Start Menu > right click on Computer > Properties. Download the software on the Lexmark website. Click on this link. http://bit.ly/aUjOD3 . Click on Downloads tab right at the center of the page. Download cjrX1100EN.exe for 32-bit or cjsX1100EN.exe for 64-bit operating system. Run the software. Hope this helps.
Mar 14, 2010 | Lexmark X1195 All-In-One Printer
How do you clean the rollers?
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
My printer will not print any documents, it does print a test page, when I select print the paper is ejected. I have re installed the software.
Try to print a self test page from the printer directly using the below steps....
  1. Make sure the printer is loaded with plain, white paper. Remove any special or colored paper.
  2. Press Setup on the front panel of the product.
  3. Press 1 , to select Print Report , then 5 , to select Self Test .After you have the report printed, check for 4 horizontal color bars in that report, the first color should be the the black one, if the black one is missing, issue seems to be with black cartridge, that may be the reason the printer spits out blank paper, try to replace the black cartridge and then copy if it copies or not.
Sep 26, 2009 | HP PSC 2210 All-In-One InkJet Printer
How do I copy a document on a lexmark x 1185 printer scanner copier
Turn the documents printed page away from you. (Document facing you, turn it around so that the print is on the backside)
Insert it in the top paper feed tray. Align the left side of the document page, with the alignment bar on the left side of the top paper feed tray. (Put the left side of the paper against the plastic bar on the left side of the paper tray)
Computer running, Windows loaded. Go to Start>Hover your mouse cursor on All Programs>Lexmark>Lexmark Printer
Click on the Copy function, and go to the Properties window to set how many copies you want, (Default setting is 1), what size paper you're using, and so on.
Jul 13, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
No booklet came with my lexmark 2600 series
For color copies, you press the function key with two pieces of paper and color dots on it. For black and white copies, you press the function key with two pieces of paper and black dots on it. The link below is to the user's guide for your printer. Page 17 shows a diagram of the function keys, also, page 39 provides steps for making copies.
Lexmark 2600 Series User's Guide
Jun 05, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x5495 all in one.paper does not come out when printing
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridge. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
May 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer
I need to know if this is a sudden occurence or has it happened before. Is cartridge new or refilled or older, and did it print right until now. Also need to know if you have made any recent system changes and if you run anti virus and spyware.
Mar 12, 2007 | Lexmark X1195 All-In-One Printer
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
