Question about Panasonic Panaboard UB-5315
Panaboard printing problems
My board prints black on the bottom half of the paper. I've cleaned it and taken it apart and cleaned everything behind it and it still prints black. What would cause this?
  • Paul Homuth
    Paul Homuth May 11, 2010
    one possible problem is part of your scanning unit is blown
Just the lower half has a 1 inch line that follows across it. From the line above that every thing else is clear and perfect the way it should work. I cleaned every thing in the dam thing but still have the 1" bar at the bottom. So from their I have no clue what to do next. Any advise would help me greatly.
Posted on Oct 01, 2008
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
My HP printer prints half on one page and half on another how can i fix it?
Pl share printer model number for better solution.. try this# go to printer menu select default settings..check# check paper size in system..select proper size# un install existing drivers, re install once again..check# print from word or excel format..checkif no result share printer model number... for better solution...Vinay
Mar 30, 2012 | Office Equipment & Supplies
My panaboard UB5815 error j but there is no paper jammed in the unit
Hi John, there may be the smallest piece right down in the throat area. Occasionall there can be some also completely rolled up in the paper shoot behind the rolls of film. I always remove the paper and turn it around prior to printing. At the end of each printing session, the next piece is drawn in and partially curled for 4cm. This will cause it to roll up inside at the next printing attempy- 9 times out of 10- Ross
Clear the error by turning off for 30 seconds.
Mar 05, 2011 | Panasonic Panaboard UB-5815
My panasonic panaboard kx-b530 printing very lightly. please help to solve this problem. Thanks & Regards N. Sivakumar
Most panasonics are dark printers. You may get some relief by using Spicer brand paper- 30% darker print.- Ross
Oct 27, 2010 | Panasonic Panaboard KX-B530 Graphic Tablet
Hi! printing flight boarding passes on Epson
run it through a cleaning mode.
in ctrl panel
select printer and r click go to
properties and then the
maintenance tab.
Run clean
Run Nozzle check
When it prints correctly
ensure you select paper size as A4 and print your pass.
Pleazse rate my help++++Thanks for using Fixya
Jun 04, 2010 | Epson Stylus C46 InkJet Printer
Cannon Pixma MP830 - smearing on front when printing
If you have taken it apart that far then you are way ahead of the game. My suggestion would be to clean the head or anything the ink touches in a vinegar/water solution. The vinegar dissolves any dried ink whereas the soap may actually gum things up. If that doesn't work or improve things I would say that your print head has a seal problem. The replacement print heads are worth more than a new printer so you can probably figure out whats cheaper to do.
Aug 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Trouble with Designjet 110plus: Cannot get Cyan or Black to print. When I change the printhead, the machine does not recognize it for both black and cyan. Machine DOES NOT show error on any printhead or...
Hi Paula, first of all, take out the Continuous Ink System. Second, make sure that the new printhead are good and work propretl, try to get them in another HP 110, if their work good and at your HP not working good whitout your Continuous Ink System replace the carriage assesmbly, but before that verify tge tubes of ink. Good look
Aug 03, 2009 | HP Designjet 110plus nr InkJet Printer
PIXMA Ip4000
I assume you're using photo paper.
Go to File/Print. Click Properties. Click Media Type and chose the photo paper you are using, whether it's Photo Paper Pro or whatever. If you're printing using Plain paper and you have photo paper in the printer, you'll get the stripes.
Hope that helps
Oct 22, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Panaboard UB 5815 Wont Print
After looking at the troubleshooting section in the manual (what we should have done in the first place before posting this lol) we realized that we just needed to simply replace the Thermal Transfer Film.
Jul 24, 2008 | Panasonic Panaboard UB-5315
Black line prints on back of paper
I have the same problem and I have not found any fix yet.
Oct 03, 2007 | Canon Pixma MP500 All-In-One InkJet...
Panasonic Panaboard UB-5315 Logo
243 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
