Question about Gateway MX6421 Notebook
Gateway MX6421 Notebook hard disk problem
My Gateway MX6421 Notebook gime blue screen corruption HD.
I have before Windows .
I tried install XP SP2 and after format HD i have the blue screen error.
I change the Hard disk , same problem.
Could help me please.
I don't have the recovery CD's
  • Anonymous Nov 29, 2008
    Yaaah, pleas somone help us i have the same problem. I bought a new hard drive for my mx6421 and it is not reading it for some reason.
  • ltoso May 11, 2010
    i can help you with this but for that i would need the error code
    what does the blue screen error message say
    any human understandable message
    awaiting clarification
    Problem Solver:
  • 50 Answers
Try the link . . .
For find your best solution.
Posted on Jul 25, 2009
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
Windows 7 not installing in Hp XW4100 workstation
Sounds like you need to format the hard drive then try a new install
Jun 21, 2012 | HP Workstation Xw4100 PC Desktop
I can't install Windows Xp Sp2 For Compaq Presario Cq60 Model. a blue screen error occured after completing the files from cd to ram before entering lience agreement
You need to check your system ram or memory. If you have 2 system ram or memory unplug the other memory and install the windows xp sp2 again. If still having a blue screen try the other memory then run the setup again. Also if you have an extra hard disk drive you can test it that or plug your hard disk drive to the other laptop and run the windows xp sp2 using your hard drive. If you can install the windows xp sp2 on the other laptop that means your hard disk drive are good. If your memory and to the other laptop are compatible plug it and run the windows xp sp2 installer to see and to diagnose what are really causing problem. Have a nice day.
Apr 02, 2011 | Computers & Internet
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
Gateway MX6421 does not boot, even when recovery disk is in. In recovery mode, splash sreen opens up, and the timing bar zips across about 3 times then freezes
well this might be the case if the recovery disc is corrupt so if you don't have any important files in the c drive its better to reinstall the OS but before that try the safe mode option while booting the pc.
good luck.
Jan 06, 2010 | Gateway MX6421 Notebook
Windows xp instalation stpos givibg a blue screen in aspire m5640 desktop
Windows Xp installtion give Blue Screen of Death when XP tries to installed devices driver during installation or when the cd is corruptted and cannot be read in graphical mode installation or when the hard drive is corrupted with Bad sector.
Get a new windows XP CD and configure your system BIOS to default setting ( load optimal settings) and configured for IDE drive configuration to compatible mode or disable mode if you are using SATA hard drive.
If problem still occured, get "Bad sector recovery pro" and try to repair the hard disk.If the bad sector are unrecoverable then change the hard drive.
Sometimes, faulty RAM also give blue screen too. Check your RAM too.
Dec 19, 2009 | Acer Aspire m5640 PC Desktop
When my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Oct 18, 2009 | Gateway MT6705 Notebook
Mass storage controller driver for gateway mx6421
A 'mass storage device' is any device on which files can be stored (HD, Memory card, thumb-drive etc.) so that controller is not for the USB ports as such, but may indeed be for a storage device that plugs into a USB port (card-reader, external HD). For a laptop, it may be for a built-in card-reader which is connected internally to the USB bus.
Go here and enter your laptop's serial number to be sure of getting the proper drivers specific to your machine, as you may be trying to use the wrong driver. Only by entering the serial number can you be sure of getting the correct files:
Aug 03, 2009 | Gateway MX6421 Notebook
Gateway MX6421 Notebook Logo
156 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
