Question about TDV Vison F173 17" Flat Panel LCD Monitor
Acer monitor 19"
I can't turn off the screen. The orange light remains on at all time when the computer is turned off.
Was working fine up to last week.
Bought it Dec. 31, 2007
  • 1 more comment
  • parenthese Sep 18, 2008
    Thanks for getting back to me so quickly.
    The light I'm referring to is the ON and OFF light on the bottom right of the screen.
    The model # is X193w. When the monitor is ON the light is blue and normally the color would turn to orange when it's idling.
    The problem is that when I turn off the computer, I can't turn off the power button. The screen is OFF but the button light remains ON.
    Thanks for your interest.
  • parenthese Sep 19, 2008
    The problem seems to have been resolved by itself. So, your answer made me understand the way it works and I can figure now why it did it.
  • Steve Allison
    Steve Allison May 11, 2010
    The orange light
    Do you mean a front panel LED?
  • TDV Vison Master
  • 5,568 Answers
It sounds very normal; when the video signal from the computer disappears, most late monitors will go to standby mode but most will also tell you it's going to sleep with some kind of message.
Turning the main system off doesn't normally disconnect the AC from the monitor so what you describe is that the monitor is plugged into a receptacle of its own, not one that you are turning off with the PC.
BTW, PCs and TVs (including monitors) aren't really 'off' when they are off. They have a small amount of current drain that serves to keep alive certain circuits so they can respond to, for example, the return of the video signal or, in the case of a TV set, a command to power up from your remote. They could not respond unless they can interpret the signal to wake up.
Posted on Sep 18, 2008
Moved my computer and when trying to hook up monitor "Acer" comes up on screen then light goes orange and nothiing
usually when you turn a monitor on it will display the company name of that monitor. Then after that it waits for the signal from the computer if there is no signal coming from the computer it usually has to do with the video card
May 20, 2014 | Acer AL1916W 19" LCD Monitor
Nothing on screen, gren and orange light flashing
You more like have bad capacitors in the power supply. Open it up and look for capacitors with bulging tops.
Common problems fro 2~3 years old monitors/ TV.
Jan 03, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
My monitor doesn't display anything, though it's receiving input from the CPU. I know that input is being received because the monitor status light is green, and times out (turns orange).
Same thing happened to me! Went to bed last night, everything was fine. Woke up today, orange light came on, no display, slight flickering seen, but that's it. Cables and cords are fine, tried unplugging and plugging it back in, NOTHING. Totally dead. I'm guess off to buy a new one today. Typical made-in-China JUNK.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
Screen went blank and orange light is on
fiona_sheeha, If ACER warranty service not an option, then unit will need local tech to troubleshoot unit's power supply/inverter circuit for possible COMMON and repairable printed circuit board fix. You must read more of my fixya profile and visit the web links you find there so you will know and understand what ALL your options are!!! Some units require less than $5 in parts to refurbish them to working status. Your "cold-cathode-fluorescent-lamp" backlit LCD monitor isn't any different than any other brand of monitor in it's basic operating principles!! I hope this helps. 12fixlouie
Dec 30, 2009 | Acer AL1916W 19" LCD Monitor
My Acer AL1714 monitor was given to me, the person that gave it to me said last time the last time it was connected it work but the monitor had been stored for about 2 years. So I bought a 19V-2.3A power...
mccampbell71 Probably a failure of inverter circuit(dc to ac 600-1100vac) to light-up (sustain) "cold-cathode-fluorescent lamps" causing the "switch-mode-power-supply" to go into full or partial SHUTDOWN mode. Black Screen of Death strikes again!!! The Question I have is why did you BUY a "black-brick" supply? Did the other one fall out of the car or get run over by a train? Only you will be able to make the decision of to REPAIR or Trade-in for new. You are no different than 5000 others worldwide (all brands) who have monitor's with BSOD! Yes, some (75-90%) can be saved to work 1-3 more years! Read some of my other responses in my profiles (12fixlouie aka louie12fix) to learn of the options you have open to you. Bye for now 12fixlouie If this info was of some use please rate on fixya.
Nov 13, 2009 | Acer AL1714 17" LCD Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
Monitor problem
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
TDV Vison F173 17" Flat Panel LCD Monitor Logo
97 people viewed this question
Top TDV Vison Computers & Internet Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a TDV Vison Computer and Internet Expert? Answer questions, earn points and help others
