Question about Oreck Vacuums
Oreck xl upright vacuum
Everything is fine, except the beater bar won't turn. There had been a pushpin stuck in it so it couldn't turn, but when I took it out, the problem is still there. Is there a reset button or something?
    Novelist:
  • 97 Answers
Remove the five screws from the baseplate and replace your belt by removing your brushroll, putting the belt over the motor pulley, and then over the pulley on the brushroll, then replacing the brushroll in its original position and screwing the baseplate on. Note that you should make sure that the bearing ends of your brushroll spin freely prior to doing this to avoid the belt breaking again.
-R
Posted on Sep 18, 2008
My Oreck platinum vacuum shuts off after a couple of seconds. Whenever I turn it on it works for 2 seconds then shuts off, any help?
Atek,
You may have received the wrong beater bar for your machine. Some of the Oreck's have an electronic sensor that detects the brush speed and the way they do that is to put a magnet embedded into the brush roll. Turn your vacuum over and spin the brush by hand and look for a metal dot about 1/4" in diameter. It should towards the end opposite of the belt. If you do not see that metal dot, you need to take the brush back to where you bought it and ask for the correct brush. If you ordered online then call them up and ask for a swap. Hope this helps!
Feb 26, 2015 | Oreck XL Platinum Pilot Bagged Upright...
Why does my Oreck upright. Acumen keep shutting off after a couple of seconds?
Atek,
Sounds like you have one of the Oreck's that has a sensor that looks for the brush turning and you received the wrong brush. Look to see if there is a metal ball embedded in the wood about a quarter or a third of the way down from the end opposite the belt end. If there is not the metal ball, you have the wrong brush roll. Getting the proper brush roller should make all the difference for you. Hope this helps!
Feb 24, 2015 | Oreck XL Platinum Pilot Bagged Upright...
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Brush roll won't turn only a few times
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
Jun 07, 2013 | Oreck UPRO14T - Vacuum Upright Commercial...
The bar on my oreck doesnt turn
1) test the belt drive for worn or broken or crack
2) bearing bar defective.LUBE
3) debris in the bar
4) motor defective repair
see the diagrams.
God bless you
Jul 19, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Hi, I have a 1 year old XL Pro Plus Upright. Motor works fine, brushes are turning but it will not create any vacuum. we made sure thenew bag is connected properly and still no suction. Any advise? Thanks,...
The belt that turns the brush bar is probably stretched and worn. Once this happens, you will lose suction. When they get worn they stretch, thus causing it to spin on the bar itself.Just simply replace the belt with a new one that fits your machine.
Good Luck!
Jim
Jul 28, 2011 | Oreck XL Pro 18T Upright Vacuum
It has no suction...
Assuming that the vacuum will run, remove the bag and check the discharge to the bag from the machine for debris. Also check the suction to the vacuum blower by removing the beater bar cover plate and beater bar. Inspect the belt. While the bar is off, inspect the suction hose behind the beater bar. This is where I usually find the debris.
Regards, --WoobieDog--
Jul 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck Commercial XL 21
Check that the beater bar is completely clear of thread, this will bring the brush roll back to normal. Also check the sides of the brush roll doesn't have anything such as thread or thick string at the sides.
Jun 16, 2009 | Oreck XL21 Bagged Upright Vacuum
Vacuum billows dust
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Nov 13, 2008 | Oreck XL2200 Bagged Upright Vacuum
Vacuums Logo
212 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
