Question about GE WBSE2090A Top Load Washer
Electrical We had a power surge at our house, and now the washer will not function at all. The breaker is fine and power is at the outlett. Can you help me with were to start and what to look for? Thanks, Jim
  • jca6701 Mar 05, 2009
    Had a power serge in my home. Electrical problem has been fixed and outlet is good. However, my GE top load washing machine will not start. It has a push button "start", and no reset buttons on the control panel. Is there a reset on the motor? and if so, how do you remove the front panel?
    President:
  • 2,976 Answers
Sometimes, there is a reset built into one of the knobs on top. There could also be a reset button on the control panel. I missed this years back when mine did the same thing. I forgot about the reset because I never had to use it... Also, if you have it plugged into a GFI receptacle (the kind with a test and reset button) reset the receptacle.
Posted on Jan 02, 2009
After power outage dryer will not come on model # 96573220
Hello Edward, Is it possible that the electrical circuit breaker is tripped in your breaker box? Try shutting the breaker off and turn it back on.
Feb 23, 2014 | Kenmore 60172 Electric Commercial Dryer
Electrical problem with FA561XF
Could be the breaker. Sometimes breakers just get old and will not hold when a power surge goes through it as when an electric motor first starts up. You have already replaced the compressor with a new one so I would check out the breaker situation. STAY with the same size breaker
Nov 24, 2013 | Smeg Refrigerators
Titan Troubleshooting
Check for small fuse on circuit board:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Water heater circuit boards are NOT protected from surge. And reset button does not protect from surge. Nearby lightning can put out any household appliance, especially since more of these things are electronic instead of mechanical.
Install single-use whole house surge protector and replace it after each surge event instead of replacing appliances.
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
The quickest solution for tankless is to replace whole thing with more reliable tank-type electric heater for $275 from local box store.
Jun 18, 2013 | Water Heaters
Moved treadmill and now its not working
1) Test the outlett power wall, and rese the c.breaker from your home
2) Test the power cord for wires loose, break or burn with VOM
3) Reset the c. breaker from treadmill
4) See if there are some wires looses
5) Tight any wires connector very well.
6) See if there are some fuse blown inside,
7) Test again. Note: NOT use any extension cord. see the block diagram for help .
God bless you
May 20, 2012 | RTO Image 15.0R Treadmill Walking Belt
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Code 28
Error code F28 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below. In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Neptune Top Load fills the water, the motor doesn't start.
If i understand correctly you are stating the breaker shut down which means the house breaker for the outlet power kicked out. You might try plugging something else into the outlet to see if it also kicks out, say a vacuum cleaner of a drill.
You need a amp clamp to test for something shorted or grounded (or ohm out windings) which requires trained service........you do not want to get a shock
Jan 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dishwasher won't start. Electrical breaker is on.
Sounds like your door switch, You can try to adjust this usually it is just two screws on the unit where the latch is.
Sep 29, 2009 | Electrolux EW1000i Front Load Washer
KitchenAid dishwasher loss of power
Electrical storms can burn out electronic components. Consider investing in whole house surge protection.
If you need assistance in selecting or installing surge protection on main power line, email me buffalonymann@yahoo.com
Jul 30, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
Had power outage and now the Neptune Washer won't even light up. Washer was not in use at the time. Checked the breaker and outlet and all live and functioning. Is there a reset button that will reset the...
no! did the porew surge when it came back on,like the lites in the house went briter than normal/may have damaged main control board in top console.you will also fine a tech sheet up there.see if you can get some glues their.God bless.tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE WBSE2090A Top Load Washer Logo
179 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
