Question about Microwave Ovens
Frigidaire FMV158FM over the range microwave 1000 watts
SE is showing on the control panel, nothing works. Wondering if it could be a fuse, and where is the fuse located.
Charlotte J.
Everything works on microwave but does not heat
Posted on Jan 30, 2011
Fridgidaire microwave won't shut off
Good Morning friend, thank you for your post!
I see that you are having difficulties with your Frigidaire microwave not shutting off. This could be a possible issue with your control panel or door switch. I would recommend performing a reset on your microwave and that can help clear out any potential miscommunications. To perform a reset you can flip the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to seek assistance from a professional technician for proper diagnosis and repair. Hope this is helpful. -Matt
Mar 09, 2015 | Frigidaire FMV152KS Stainless Steel 1000...
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
Microwave error code se
That would be a shorting membrane keypad.
On most of these, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Apr 22, 2013 | Amana AMC5101AAS Stainless Steel 1000...
Ran microwave w/o food inadvertantly. Nothing works, no display. Breaker swith OK.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Maytag owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 13, 2010 | Maytag MV1153BAW 1000 Watts Microwave Oven
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
KitchenAid microwave #kcms135gss just stopped working no clock display , changed to diff outlet still nothing
You probably have a blown internal fuse or thermostat (one is on the top of the cavity and one is on the magnetron).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
Dec 05, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Does not heat
I WOULD SAY REMOVE THE CABINET FIRST AND GO FROM THERE. IF YOU HAVE NO POWER THAN CHECK THE FUSE.
Apr 13, 2009 | Electrolux Over-the-Range Microwave
Microwave Ovens Logo
498 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
