Question about Compaq NC8000 Notebook
BATTERY NOT PRESENT
BATTERY DOES NOT CHARGE AND WHEN YOU REMOVE THE POWER IT SHUTS DOWN THE COMPUTER THINKS THAT THERE IS NO BATTERY PRESENT
  • PAUL2U Sep 24, 2008
    COUSE YOU'RE STATING THE OBVIOUS! HOW CAN U CALL THAT HELP EVEN A MONKEY WOULD HAVE TRYED THAT BE FOR ASKIN! THE COMPUTERS ARE NEW AND THE BATTERYS DONT CHARGE AN THE COMPUTER THINKS THAT THER IS NO BATTERY THERE AN YET THE BATTERYS WORK IN A SIMILAR MACHINE?
    Genius:
  • 1,124 Answers
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or new or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Posted on Oct 18, 2008
  • Pablo Csaky
    Pablo Csaky Oct 18, 2008
    If also your computer shut down after battery has been removed is related to point (3)
  • david_jeffco
    david_jeffco Jan 23, 2013
    I have a Samsung P30 laptop with the same problem. I have replaced the battery and there is no change. The battery is shown as not present within Control Panel and the computer shuts down immediately when I disconnect the mains power. I think I need to replace the Corona Power Board, which is available on the internet. Is it difficult to replace?I have previously installed extra RAM chips without problems.
  • 6,487 Answers
If that is an old battery , it only means that the battery is already dead and needs a replacemenet, but if that battery is new make sure that the battery is charging if its not changing the prokblem can be the battery still....
Hope that helps...........
Posted on Sep 18, 2008
  • Mark Gil
    Mark Gil Sep 19, 2008
    Can you please inform me why yu rate my solution Inappropriate? you should just ask me for some help and didn't rate me like that I'm just trying to help you,, if you can please change the rating and continue asking some help from me that will be better....
    Thank you,,,,,
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
Battery in compaq nc6210 saying not present
How old is the battery and did the problem happen sudenly. If the unit has been left in power down i.e. the lid just shut and you left it for a while i.e days/weeks before trying it again then the battery maybe too low to register so the laptop does not try to charge as it thinks there is no battery.
Jan 15, 2014 | HP Computers & Internet
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
My computer shuts down and I have to unplug the ac and remove the battery to get it to restart
Cold start issue. Your computer likes to be warm.
This could be because it has run too hot for a long period of time. Some damage is possible.
What you need to do is let it breath, airflow is important. Clean the intake and exhaust vents with a vacuum cleaner.
Always remove the battery from the notebook if using the AC power adaptor, unless you need to charge the battery. Maybe it's the battery that likes to be warm. Makes sense because a warm battery pack outputs more energy.
Power your notebook only off of the AC power adaptor, this may be the solution you are looking for.
Take care!
damnor01
Apr 28, 2012 | Computers & Internet
New battery in Acer laptop shuts down computer at 44% power ?!?
In the power options at the control panel you can set the battery options there to shut down at a lower percentage. Also within the software for your battery as well. At the task menu lower right hand corner tick the battery settings. John
Apr 09, 2012 | Computers & Internet
Battery will not charge.plugged in not charging
Does the computer start anyway, but it's just that the battery won't charge? If that's the case, it's probably a bad battery.
A procedure to do before assuming a bad battery is to (1) remove the battery, (2) disconnect the power supply from the computer, and (3) press and hold the power button for about 30 seconds. This resets the logic circuits in the internal power handling section. If that doesn't help either, then the battery is probably bad.
If the computer isn't starting, however, it could be that the power supply has failed. Check the voltage output on the power supply.
Hope that's helpful.
Jan 12, 2011 | IBM ThinkPad T30 2366 Notebook
My sony vaio doesn't recognize the battery and thinks that the battery is not present or bad. I replaced with a new battery and still have the problem. Over the past year, the battery life indicator has...
May need to remove the CMOS battery for 1 hour.
This is technical task that involves stripping laptop completely.
Is the new battery same brand or "pirated" as the vendors one should be recognised
Mar 29, 2010 | Sony VAIO VGN-FS550 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Dell d410 laptop won't charge battery charger doesn't like the ba
There's a problem with the motherboard.
I would say try a bios update, but I believe it requires both battery and power adapter to be present before it will flash the rom.
The above probably won't work but it's always good to try the easy stuff first.
More than likely you'll just have to replace the board.
If you have any more questions, feel free to ask.
Feb 24, 2009 | Dell Lattitude D600 W/XP Pr Notebook
Compaq NC8000 Notebook Logo
730 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
