Question about HP LaserJet 1320 Printer
HP lazerjet 1320
I am getting what looks like roller marks down one side of the page which started quite suddently towards the end of life of one cartridge. However, this hasn't improved with the new cartridge, cleaning rollers etc.
  • 4 Answers
It is most likely the fuser.
Posted on Sep 24, 2008
  • jtgreene815 Sep 25, 2008
    You can run a half stop test. If the marks are not on the page before it gets to the fuser, then you know that the fuser is causing the issue. Run a test from the multi purpose tray, but open the cartridge door as the paper gets a little past half way into the printer. Remove the cartridge and check the page. If you have the same marks on the page, then you have a cartridge or high voltage problem. If the marks are not present, then you can be pretty sure the fuser is causing the issue.
  • 446 Answers
If your roller mark seems grayish it could be cause by a dirty roller in the paper path, open up your printer and clean with alcohol, there were some cases that the rollers were somehow softened and causing mark along the prints if this is the case you need to send thi to a tech for a part replacement
Posted on Sep 18, 2008
Black horizontal lines
recharge(with new OPC, PCR and mag roller) or try another cartridge - if problem not solved - fuser film damaged
Jun 09, 2013 | HP LaserJet 1320 Printer
My printer hp laserjet 1320 output is light why
The two common things that cause this type of problem are:
1) low toner - remove the toner and shake it from side to side to distribute the toner evenly in the cartridge to test. If the print gets better then you need to get a new toner cartridge because your is almost out.
2) The transfer roller that charges the paper to allow the toner to transfer to the page is worn out and will need to be replaced. The roller is user replaceable and comes in the maintenance roller kit that you can get here:
http://www.ccl-la.com/catalog/product_info.php?products_id=71
Replacing the rollers takes about 10 minutes or less.
I hope this helps you get your print going again.
BuddyMc
Oct 02, 2012 | HP LaserJet 1320 Printer
When i trunn on and when i want print all ways stuck
if you see brown marks on the center top of your page then its your feed roller... hp feed rollers come out easy... Get some rubbing alcohol or hand sanitizer solution and clean with a paper towel... Make sure to dry your feed rollers then put them back in... that should clear up your issue... if that still does not work you may need to replace feed rollers
HP LASERJET 1320 FEED ROLLERS TRAY 2
If it feeds ok but gets stuck at the back then chances are your fuser is bad. The belt is most likely ripped.
HP LASERJET 1320 FUSER ASSEMBLY
Sep 12, 2012 | HPLASERJET1320N LASER Printer INTEGRATED...
HP LAZERJET PRINTER 4200N. WHEN PRINTING, LEAVES INK MARK DOWN ONE SIDE OF PAGE.
you may need to poke down the absorber foams below the ink cartridges. See if accumulations of blotted ink takes place. Wipe it or spray some windex. You may also need to wipe the roller with dampened clothe. Printed of the ink cartridge ma also need to be clean. Softly press it in a towel moistened with alcohol to remove ink residue in the print head.
Feb 02, 2011 | HP LaserJet 4200n Printer
I am getting lines down the middle and blotches on the other two sides of the page up and down. I have ordered a new refurbished cartridge and some cleaning paper to try this first. If this does not work...
may be it caused by your printer roller not work properly, try to clean roller, if not work check the roller, case off printer and see the roller may be the roller gear ware not work properly and caused noise
Jan 11, 2011 | HP LaserJet 1320 Printer
Our hp laser jet 1320 has black lines running horizontally on the page. Is there something we can do to clear this problem up?
Get the toner cartridge out from the printer, move the plastic cover so you can se the light green roller. On both ends of the roller are gear wheels, use your fingers to rotate them and see if there is any toner on the green roller (lines). Check if there is some piece of paper or some dust or dirt on the roller, and if there is, gently wipe it with the dry soft cloth.
If the problem persist, try changing the toner cartridge.
Nov 05, 2010 | HP LaserJet 1320 Printer
Paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP LaserJet 1320 Printer
How do I clean the rollers on my laser jet printer, it prints with a long black strip in the middle of the page. Hp laser jet 1320
Most likely the heat roller is breaking down in the fuser. The fuser must be replaced. But before going that far, replace the toner cartridge, as it may have a bad cleaning blade. 85% of all print quality defects are cartridge related. This particular model of machine has a very brittle heat roller that more often than not wears out prematurely. This is true across the board for all of the newer HP low end laser printers unfortunately.
Sep 30, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Jun 30, 2009 | HP LaserJet 1320 Printer
Toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
Feb 28, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
501 people viewed this question
Seeker5211
Seeker5211
