LED wiring colr code
In a computer case the LED wire is white for one lead side and orange for the other. On another it is balck anf the other is red. Which is the negative side color. I am using a Mwav computer case.
    Genius:
  • 1,148 Answers
Usally theres one that is black and white, ,,,orange and white,,,red and white,,, and so on,,, thr whiet is the negative
Posted on Oct 05, 2008
How to wire for 220 v
220 is two hots and one ground. If it were me I would leave red orange and white "together",then verify your voltage on remaining wires. 110, 110, 0. If not, youre no good. Try something different. It doesn't matter what "line" goes to what "load" just as long as one of these goes through whatever relay/switch you are using. Good Luck. Hopefully single phase. If motor runs backwards swap wires.
Mar 14, 2017 | Heating & Cooling
I have a 1/3 hp through the wall dayton exhaust fan. It has (3) wires, Balck/white and red. What isthe red for?
The motor should show wiring on its side, if not my guess is that its another speed, black is high and red would be low or a slow speed you use either black or red not both unless you have a relay to control the switching tape up the unused lead or it will short out.
Jul 06, 2011 | Heating & Cooling
Wat do all the wire cables mean at the back of the stereo? e.g.- brown, white/purple.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Ground Wire: Brown
Car Radio Antenna Trigger: White
Left Front Speaker Wire (+): Yellow/Red
Left Front Speaker Wire (-): Brown/Orange
Right Front Speaker Wire (+): Black/Red
Right Front Speaker Wire (-): Brown/Orange
Left Rear Speaker Wire (+): Yellow/Black
Left Rear Speaker Wire (-): Black/Orange
Right Rear Speaker Wire (+): Blue/Black
Right Rear Speaker Wire (-): Brown/Orange
Apr 18, 2011 | 1993 BMW 7 Series
Hi, I have a Cobra 29 NW ST CB Radio and I was wondering something about changing the stock burnt out bulb to an LED. Does it matter which wire goes to the negative side of the LED and which one is the...
LED's do matter how they're installed.
Test your LED leads w/ a batt. first before soldering in you 29 board.
Look at you existing leads from you burnt out bulb. One red?
Then its your Pos terminal. when your LED lights up on your Batt. test you'll know which one is the POS/NEG legs. then resolder it into your board.
Mike
Dec 31, 2010 | Cobra 29 LTD CB Radio
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Radio works just have no digital read out on 1999 explorer. Is it fused related?
Hello! Yes It could be fuse related. You have lost power on the Blue/Red lead, which is illumination to the radio.
If you have a multimeter you can look for +12volts on this wire with the key on. If it is not present; Check fuse #27 15amp inside drivers side fuse box.
In case you ever need the entire wiring; Here it is...
Green/Yellow memory +12volts with key off
Yellow/Black ignition +12volts with key on
Red Ground
Blue/Red +12volts with key on
SPEAKERS
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Guru...................saailer
Jan 12, 2010 | Bose Car Audio & Video
I want to replace my new exit sign with the
If you have 120 volts to the box, then just put a piece of tape or wire nut on the orange wire, and connect the black and white wires to the wires in the box. If it is 270 volts to the box, then connect your black and orange leads to the wires in the box.
hope this helps
Oct 01, 2009 | Sign Led Emergency Exit - Red
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
MSI MS6511 jumpers overview?
Dear User here is confiruration.
1.Orange with + sign and orange is for HDD LED.
2. Green with +Sign and Green is for Power LED.
3.Red is for Power switch.
4. Blue of Black is for Reset switch
Mar 29, 2009 | Computers & Internet
Hooking my Neo4 mobo back up.
Hi weeman105, case wire colors do vary from case to case. The most common case wire colors for negative are "white & black". All other colors like blue, green, red orange are most commonly "positive". The four pin connector with only the ends with wires is the internal speaker. Most boards use one set of pins where you hook everything up. The MSI K8N Neo4-F uses two separate motherboard pins, Front Panel Connectors: JFP1 & JFP2 as shown on the top page 2-19. Now that you know what color is positive & which is negative things should work out just fine.
Downloaded manual from MSI link: http://global.msi.com.tw/index.php?func=downloadfile&dno=4117&type=manual
If you run into any other troubles, just post & we'll go from there.
Good luck weeman105!
Mike
Sep 13, 2008 | MSI K8N Neo4-F Motherboard
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
