Question about Ricoh Aficio 450 Copier
Error code sc550 - Ricoh Aficio 450 Copier
Ricoh jp 5500 Copier Error code sc550
Posted on Apr 15, 2011
  • Ricoh Master
  • 2,794 Answers
It's fusing web end error code.  The fusing assembly needs service work done on it.
Posted on Sep 18, 2008
Error code sc550
Needs the web to be replaced.
Jun 17, 2014 | Gestetner Office Equipment & Supplies
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
Error code sc550
That error code refers to the FUSING WEB END.
First of all you must see if the fusing web is end.
If the error occurs before the web ended you have to upgrade your firmware. There is a release firmware that corrects this symptom.
Jul 06, 2011 | Office Equipment & Supplies
Ricohaficio2060sperror code sc550
After replacing the canvas with a new one, you must
SP1902 perform -001 (Display / setting area used linen
fusion) to reset the counter to zero consumption.
The SP code should be performed to remove SC550.
Jun 20, 2011 | Ricoh Office Equipment & Supplies
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
Sc550 error code
You can try to clear the code by doing this press the yellow all clear botton, then press 107, then hold the stop botton for 3 sec. Then turn the copier off then back on. It works on most Ricoh copiers
Jun 22, 2010 | Ricoh Aficio 450 Copier
Photocopier comin up with error sc550 on gestetner 1302
The problem in the fusing unit.Clean and verify the heater lamp,thermistor and thernofuse continuity.
Sep 26, 2009 | Gestetner Office Equipment & Supplies
Error code
May 05, 2009 | Office Equipment & Supplies
Multifunction machine doesn't work
I think you mean "SC550"....all codes are 3 digits. If this is correct, it mean that the Fuser web has expired, and needs replacement, then and only then can the code be reset in service Mode. Call a tech.
Mar 12, 2009 | Ricoh Aficio MP1600SPF Copier
Aficio 1060 - SC550
• Web end (requires replacement) fusing unit
• Web end sensor defective
Note: After replacing the web with a new
one, reset SP1902 001 to 0 to
release SC550.
Jun 28, 2008 | Quasar SP-3235 32" TV
Ricoh Aficio 450 Copier Logo
1,736 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
