Question about Toshiba Satellite Laptop Cooler
Toshiba celeron satellite cooler replacement
Toshiba Satellite Laptop with error message "Cooling System failure, Cut off immediately Take to Service Center"Is this a recall or under warranty?
My laptop is not under warranty I need to replace the fan, where can I find it?
    Scholar:
  • 157 Answers
First.you can find the processor fan in some computer shop,but i dont know if they will give you.second,check the model # of the fan and check in the internet for delivery or else,you can repair the fan by replacing the dynamo of the fan with another model of fan,just anly remove the screw of the fan and try to find another model fan and replace the dynamo fan.
This kind of issue is i try with some of my customer because they cant find the same model of fan.
Posted on Dec 31, 2008
Message keeps popping up saying Turn off computer, problem in cooling system
you need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Nov 25, 2013 | Toshiba Satellite 1715XCDS Cooling Fan...
Hi there is a toolbar coming up the whole time saying,,,,,WARNING a problem with the cooling system has been detected, please turn of the computer and return for service immediately
Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
Welcome to FixYa! Based on the error you have received, this means that the cooling fan of your laptop needs to be cleaned and checked at. This is a common problem with any toshiba laptop. I suggest checking the heatsink of your laptop. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
  5. If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Hope this helps! Thank you for using FixYa!
Jul 27, 2011 | Toshiba Satellite 1715XCDS Cooling Fan...
Hi, I have a new Toshiba Satelite L500 laptop. From the moment I started to work with it, following message began to appear: Warning: A problem with the cooling system has been detected. Please turn off...
first you should install an independent system temperature monitor like speed fan and check if your computer temperature is ok .If the temp is ok then it is not as much of a worry but more of an annoyance if it shows the computer is hot take it back to service immediately either way they should fix the problem under warranty.
I hope this helps Andrew A
Apr 01, 2011 | Toshiba Satellite Laptop Cooler
Toshiba A45 S151 Cooling system probelm.
Just to be sure, check the temperature of the system with any 3rd party softwares and see whether its in the optimal range.
Jun 03, 2017 | Toshiba Satellite A45-S151 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
My Toshiva sound drive is gone, now no Audio,pls help me out. u can get to through ghalirogo@yahoo.com or +2348023702045. best regard, Ghali S.Rogo
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-1715XCDS/download/page,sh,30795,221,19,.html
go here for your drivers
Sergio
Mar 26, 2009 | Toshiba Satellite 1715XCDS Cooling Fan...
How to fix my Toshiba laptop in cooling system please ?
you probably need to clean the cooling fan...it collects dust over time, and doesn't move the warm air out as it should...its fairly accessible by removing the bottom case cover...please rate my response.....
Jan 29, 2009 | Toshiba Satellite 1715XCDS Cooling Fan...
Toshiba Satellite Laptop Cooling Failure
The fan has failed - warranty if in the time period since purchase.
Jun 30, 2008 | Toshiba Satellite Laptop Cooler
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite Laptop Cooler Logo
391 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
