Cd player says no cd magazine - Audio Players & Recorders
    Genius:
  • 1,550 Answers
Clean the laser lens
Posted on Sep 18, 2008
Why does my cd player say cd error & make cd skip
cd magazine/ player is going bad. most likely its the springs that keep it balanced while it spins the discs
May 14, 2014 | 1999 BMW 323i
My pioneer PD-M426 seems to only play disks 3 and 4 even when the magazine is full, sounds like its trying to spin the disk but failing..??
Please remove the magazine and check if there is warping within the magazine which can cause misalignment. In such a case you will need to replace the magazine . Also check all the CD's within for any damage, sometimes some spurious types can warp with heat.If so it will not load and play. Test in another cd player to confirm.Also clean the optical head within the player if this fails to read or else the optical head can be also weak.
Mar 11, 2012 | Pioneer Audio Players & Recorders
How do I remove a stuck 6CD changer magazine?
Our Bose has a 5 CD player, So, I'm not sure if this is the same for your base unit, but here goes. You'll need: a bright light and a small screwdriver that reaches inside the chassis (or equivalent).
1. Disconnect the base unit from the system.
2. Turn the base unit upside down and find the access hole embossed with "Manual magazine release" on the CD player side.
3. Using a bright light, look inside the base unit at those access holes and find the fine spring and locate where it fastens to the sheet metal of the CD player.
4. When you find the spring you should see that it connects to the CD player chassis at the forward end and a piece of sheet metal that is on top (actually underneath when the base unit is right-wide up) of the CD player chassis at the rear end. This is the manual release mechanism.
5. Using the small screwdriver, push the release mechanism rearward to release the CD magazine from the player. The magazine should pop out.
If the magazine is not released, then the CD that is still in teh player has not been slid back fully into the magazine. In this case you'll need to plug the base unit back into power and hope that the CD is retracted, allowing you to push the release mechanism rearward. If not then you'll have to open the base unit to access the CD player.
Feb 19, 2011 | Bose Lifestyle 20 System
Missing the cd magazine
THERE IS NOTHING TO FIX ON THIS, THESE CD PLAYERS ARE AMAZING PLAYERS, I HAVE OWNED 11 OF THEM, I JUST CONTINUE TO KEEP UP GRADING THEM, I PERSONALLY WOULD RECCOMEND GETTING SOME MAGAZINES FOR IT, IF YOU ARE IN THE NEED FOR SOME MAGAZINES LET ME KNOW, I HAVE SOme
thedannydude900@yahoo.com
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
Do we have to have the PD-M423 CD magazine for our player
I have 14 magazines (CD holders) that I want to sell. I also have a unit and the remote to sell too.
Jan 01, 2009 | Pioneer PD-M423 CD Player
JVC CH-X11 12 Disc CD Player
Please check is this CD Magazine you required for your JVC CH-X11 CD Player?
If yes, further details are also there.
Oct 03, 2008 | JVC CH-X1100RF 12-Disc CD Changer
Original CD Player in Mk4 Golf Tdi 1999-2000
DID YOU SOLVE THIS PROBLEM IF SO WHERE DID YOU GET THE MAGAZINE FROM I HAVE SAME PROBLEM
Jul 31, 2008 | Car Audio & Video
Error 99 displayed on cd player. CD player is a Denon DCH-520.
Normally you just hold down the eject button on your stock head unit and it resets the mico computer
Dec 12, 2007 | Denon Audio Players & Recorders
Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Jul 29, 2007 | Bose Lifestyle 30 System
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
55 people viewed this question
 Grubhead
Grubhead
