Question about Pyle Car Audio & Video
All settings for my plye dvd player restarts anytime i turn the ignition on.
    Genius:
  • 1,550 Answers
Check if the stereo direct positive lead is right connected.Good luck
Posted on Sep 18, 2008
How can I fix the cd tray on a plye PTTCSM60 stereo?
I would use an optical disc player cleaner, you know, the one that looks like a CD? Then I would check the CD for damage and dirt. Clean it with a VERY soft cloth, being careful not to scratch it. If the CD is damaged, you might try another CD.
Apr 27, 2014 | Pyle Home PTTCSM60 Turntable Boombox With...
I bought eight dvds of Jeeves & Wooster, I think it is a US production, it won't play in my recorder. I was told if I changed the area code 00, it would work. I followed instructions of Victor,...
Hi mwdiadem ,
Panic is unavoidable in case we are worried about something which we are not much aware.
The problem that you have mentioned about factory settings is nothing to worry about.
Factory settings are jut the default settings that are set by the manufacturer for the DVD player , this will not harm your dvd player but in case there are any incorrect settings by you , you can anytime choose this option to go back to the default for the dvd player...:)
Hope this helps ...:)
May 10, 2011 | Televison & Video
Unlock code region hts5560
Open the Philips HOME SCreen,...
Type on your remote: 13893108520
This will display all of the current settings for your player.
Region_Code: DVD(2) BD(B)
This will not change any settings, but will report your current settings. So it's a reporting function only.
To change your DVD region settings try the following:
Turn on player with no disk inserted
Press "Open/Close" on the remote control
Press 259 on the remote control
After enter the code 13893108520 again on the HOME Screen and the player will show region "0"
Now the buttons on the front of the player do not work anymore.... You will need to go to SETUP and click on RESET FACTORY SETTINGS....
Wait until the player restarts and now you can play all DVD regions..... ;-)
Oct 16, 2010 | Philips Televison & Video
Have motorize dvd touch schreen jensen vm9412, before it doesn't show any image on the screen, then later on it doesn't open anymore.how can i fix this?
there is a setting on your dvd player which you will have to turn off.the dvd player is set by the factory to not display the screen when the ignition is on for safety reasons but can be easily turned off in the settings menu
May 04, 2010 | Car Audio & Video
How do you get dvd player to work
you have to go into the settings and turn of the safety button.dvd players are set not to work when the ignition is on for safety reasons but can be easily turned off
May 04, 2010 | Phase Linear UDV9010 Car DVD Player
DVD player re-sets with ignition
either bad ground at headunit or you don't have tha yellow 12+ constant wire on the jvc hooked to an actual 12+ source maybe it is not a source that is capable of the amount of current that jvc needs
Mar 15, 2010 | Car Audio & Video
How to bypass the plye tv deck to play while driving
you need a 2 way toggle switch, then solder ground to one side, and find brake wire from radio harness and solder that to the other side of toggle switch, then flip the switch to on and your ready to watch and drive, disconnected harness from radio first
Feb 20, 2010 | Jensen VM9510 Car DVD Player
WHY NOT PLYE MP3
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Sep 27, 2009 | Apple iPod nano
Pyle dvd player dome light
You need a third wire
The 12V Red need to go to a constant positive (battery) the yelly needs to go to the positive from the two wires, and the ground should go to the ground for the two wires
Feb 05, 2009 | Pyle Car Audio & Video
Car Audio & Video Logo
49 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
