Question about Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
How to change a start switch, and a lighted bottom element switch on a Bunn Omatic 3 station coffee maker (with a hot water spout on the side)
  • Kevin
    Kevin May 11, 2010
    Is this a bunn stf model ? the faucett would be on the right side
  • 131 Answers
Unplug your brewer, take the 2 screws off of the lid, lift the lid, and you can see your switches from there.
Removal and Replacement for start switch;
1. Remove all wires from the switch terminals.
2. Compress the clips inside the hood and gently
push the switch through the opening.
3. Push the new switch into the opening and spread
the clips to hold the switch captive in the hood.
4. Refer to the List below When reconnecting the wires
BLU to Timer
WHI/ RED to On/ Left Switch
WHI/ RED to Liquid LevelControl Board
The warmer switch is replaced the same way, just make a note of which wire goes on which terminal when you take it off so you can replace them to the proper place. These switches are easily found at any local Bunn repair shop.
Posted on Feb 13, 2009
Pour omatic
If it is getting HOT and no water dispensing > Make sure water out let spout is CLEAN and clear.
Jul 26, 2014 | Bunn Pour-O-Matic VPR
We have an older style white Bunn Pour-omatic coffee maker. Model GR. Model # D-267.325. We are looking for the nozzle that screws onto the bottom of the water tank and disperses the water into the...
you should be able to go online and locate a bunn service centre in your area, contact them and purchase a 5 hole sprayhead. It will be metal instead of plastic but will work fine.
Sep 05, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
When we go to brew a pot of coffee, part of the time the filter housing will over flow water and grounds
Most likely you have a clog in the filter container. Use a toothpick to clean the small spout at the bottom. Then hot soapy water. Hopes this helps.
Aug 17, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My Bunn coffee maker just quit. No hot water, no brewing sounds, no heater. Is it the cord or is it just done? Help!
Unplugged, check the wire connections, heating element and thermostats
You need to have a volt meter for this job.
Jan 18, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My Bunn Pour-Omatic coffee maker (White) Heat up
Most likely suspect is the thermostat, however you might want to check the limit switch also(located on boiler between elements).
Jun 18, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
No hot water for coffee? model twood12619-1900w.
It sounds like your heating element or it could just be your heating plate.
I found this information that might also help you out. I found it
Basic maintenance can minimize repairs. Periodically brew a batch of water without the grounds, adding a small amount of vinegar to the water to neutralize accumulated acids. In addition, if you live in an area that has hard tap water, only use distilled or filtered water in your coffee maker. Not only will it last longer, the coffee will also taste better
Apr 16, 2009 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Getting to hot
The thermostat or tank heater is not working properly. Please get the model and date code located on the bottom of the machine and contact customer service. If your machine is 3 years old or less, it will be replaced free of charge. If you machine is over 3 years old, it will be replaced at a reduced price.
Jan 17, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn pour omtic 3 burner commerical coffe maker model 666L (pin # 658) Coffee maker will not brew red light comes on and flickers followed th set up insturctions still nothing, even put a pot of vinegar...
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Dec 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn auto coffee maker two warmer, only makes about 3-4 cups
The machine will allow you to brew from 4-10 cups. It works on a displacement systems so if you pour in 4 cups of water, then 4 cups of coffee should come out. If it isn't, then get the model and date code from the bottom of the unit and call customer service. If you machine is 3 years old and less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Dec 02, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
272 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
