Question about Creative Labs WebCam Live!
NO IMAGE IS SEEN ON THE CAM
IN MY WEBCAM THERE IS NO FACE OR NOTHING IS VISIBLE ONLY BLACK COLOR IS COMING, PLS TELL US HOW TO SOLVE THIS
  • sivakonguece May 11, 2010
    my web is no face or only black colour ic coming, reply me
Kamera cd drive nya rusak jd tdk ada drivernya. SO Win XP, kmrn download berhasil tp gambarnya tdk jelas
Posted on Sep 23, 2008
I have a creative live cam and it has a blue line in the middle of the screen
Lighting
Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu.
Feb 01, 2013 | Creative Labs Live! Cam Voice Webcam
I cant get my persario cq56 notebook computers web cam opened
Activate your webcam [START then PROGRAMS and then choose your webcam - usually in MediaSmart]. If you are able to see a live image on the screen it means your webcam operates properly. Now your should check the SETTINGS of your webcam [the icon] and see if under SNAPHOTS the adjustments are fitting your needs.
Because your capture is totally black I'd assume you have wrong values for BRIGHTNESS, or for CONTRAST [or for both...]. There is where the adjustments come.
GOOD LUCK!
Apr 06, 2012 | Computers & Internet
If i use my webcam it only shows black image
make sure in the webcam setting you have choose the right webcam. all depend what messenger you using. do a webcam test in the messenger you using
Jul 14, 2009 | A4tech PK-635 Webcam
Divided screen
reinstall it ...it should solve the problem ...if the problem persist after the reinstallation ...it is something wrong with the web cam
Mar 02, 2009 | Logitech QuickCam Communicate STX Webcam
Computer not recognizing web camera
The only other thing that I would suggest you try to do is (if possible) goto another PC or maybe a friends PC and plug the web cam in. If it does the same thing then the web cam no longer works. If it does work, then you may want to try another USB port on your PC.
Jan 23, 2009 | Logitech Webcam
Vga web cam gigaware
.Normal {margin:0.0pt; margin-top:0.0pt; margin-bottom:0.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Times New Roman"; font-size:10.0pt; color:Black; font-weight:normal; } H1 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:18.0pt; color:Black; font-weight:bold; } H2 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:16.0pt; color:Black; font-weight:bold; } H3 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:14.0pt; color:Black; font-weight:bold; } The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn an iso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Apr 21, 2008 | Radio Shack VGA PC Camera Webcam
Web cam reflection i see my face duoble on other camera
Please be more specific with the problem. What service / program are you using when this problem occurs?
Dec 29, 2007 | Logitech QuickCam Pro 4000 Webcam
Acer crystal eye webcam cant use in yahoo messenger
Image Size not Supported By Webcam ...Then Later On It Says Webcam Not Found ....In Yahoo Messenger Can Anybody Fix it up
Dec 15, 2007 | Acer Aspire 5610-4648 Notebook
Only black and white!
I have the same problem. I instaled the driver with lot of problems but I made it work. Only in (black and red).
Who can help us
Dec 09, 2007 | Logitech QuickCam Pro 5000 Webcam
Creative Labs WebCam Live! Logo
89 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
