Question about Lexmark Office Equipment & Supplies
Lexmark 100.02 service ITU error - Lexmark Office Equipment & Supplies
  • 32 Answers
SOURCE: 100 ITU error
Have you recently replaced the ITU? If it is saying ITU Maintenance, then the kit needs to be replaced. If you have already purchased and installed a kit, the reason this error is coming up is because the second transfer roll (small roller under the ITU) is not installed properly. Otherwise, you should purchase and install a new ITU maintenance kit.
Posted on Jul 24, 2009
Printtech
  • 1087 Answers
SOURCE: my lexmark c782 keeps coming up 100.01 ITU error.
That usually means that the intermediate transfer unit(ITU) is defective but try these troubleshooting steps found in the Lexmark website. Just go to this link: http://bit.ly/dzs6o1. Follow the instructions but if all else fails, I suggest you contact Lexmark Technical Support.
Posted on May 04, 2010
SOURCE: my problem is : 30 ITU error with lexmark c760
http://www.lexmark.com/publications/pdfs/c760/eng/userref.pdf all explained in manual above.
www.laserpros.com/pdf/LX-5060-C760-C762-Manual-toc.pdf
Above is a service manual.
Posted on May 19, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: 100.01 Services ITU Error, Lexmark
From the Lemark Service manual
A 100.01 ITU error indicates that the printer did not detect the ITU belt home sensor. Before proceeding with this
service check, make sure that the Second Transfer Roll is correctly installed. After you reinstall the Second
Transfer Roll, check to see if a 100.01 ITU error is still displayed. If a 100.01 ITU error is still being displayed,
continue with this check.
The ITU has an optical sensor that watches for a piece of reflective tape on the inside of the image belt. This
tape is read every revolution of the belt. If a signal is not received from the belt sensor within a certain time
period, the printer posts an error due to the loss of signal. There are several causes for the loss of signal. First,
the belt has tracked too far to the front or rear of the printer. In this case, the belt is still turning, but the reflective
tape is no longer passing within view of the belt sensor. This is considered a belt tracking error and is initially
posted as a 100.02 ITU Error. The other causes of a signal loss could be a belt stall, meaning the belt is not
turning, or a true signal loss, which would be due to a bad sensor, broken cable, loose connection, or bad
system board. These other causes post as a 100.01 ITU Error.
To assist the printer in determining the cause of a signal loss, there is a buffer that records the belt position for
the last 50 revolutions. If the printer loses the belt signal, it refers to the buffer. If the buffer shows significant
mistracking before signal loss, it will post a 100.02 ITU Error. If the buffer shows that the belt has been tracking
in the center before signal loss, it posts a 100.01 ITU Error. Due to memory restrictions, the buffer is not saved
during POR. This means if a printer posts a 100.02 ITU Error, so the belt is tracked off, and the customer or
servicer turns off the printer to clear the error, when the printer starts up, it will still not see the belt signal and will
now post a 100.01 ITU Error because the buffer is empty. When servicing a printer for a 100.01 ITU Error, it is
important to view the error log. See "Display Log" on page 3-29. The error log can only be displayed at this
point. Do not try to print the log. Look for past occurrences of 100.01 ITU Errors preceded by a 100.02 ITU Error.
Posted on Apr 25, 2011
Lexmark 264 30.61 error
la prin saya masih baru itu, sayang harga mahal. aku pake epson 1390 belum lunas modal itu
Aug 27, 2013 | Lexmark All-in-One Printer with PictBridge
100.01 Services ITU Error, Lexmark C782
Apr 13, 2011 | Lexmark C772dn Laser Printer
STREAK ON ITU OF LEXMARK C782
The only thing that helps is replacing the ITU.
Jul 09, 2010 | Lexmark C782dn Laser Printer
My problem is : 30 ITU error with lexmark c760
May 19, 2010 | Lexmark C760 Laser Printer
My lexmark c782 keeps coming up 100.01 ITU error. Please help.
May 04, 2010 | Lexmark C782N Laser Printer
103 service ITU ERROR
lexmark basically has said that if this error doesnt clear by powering off the machine and powering it back on again then it will need to have a service call. this error means there is a problem with the itu belt assembly.below is what they say. the steps were to pwoer it off and back on again using a grounded wall socket
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2
No:
Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
No: Print a test page. If the page prints, the printer is functioning correctly.
Nov 19, 2009 | Lexmark C760 Laser Printer
Error Code 23.05 ITU Missing
ITU is missing or defective. Replace the ITU and the problem should be solved.
Gerrit Jan
Nov 04, 2009 | Lexmark C780dn Printer
83 itu maintanece
You replace the ITU it has reached its end of life cycle.
Jan 22, 2009 | Lexmark C762 Laser Printer
868 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
