Question about Denon Audio Players & Recorders
My DRR-M30 Cassette Player has started to reject tapes when loading. I have used a dry head cleaner tape and a demagnetiser to no avail. Do you know why ? Regards, Alan Morgan
  • alamo18 Sep 18, 2008
    I should imagine the belt would be relevant to a speed problem.
    Thanks anyway
    alan
    New Friend:
    Problem Solver:
  • 7 Answers
Http://www.fixya.com/support/t12006246-ive_got_denon_drr_m30_keeps_poping_back
The solution above from AlecBrown133 above fixed the same problem for me. The only comment that I would add is that the same repair can be done with a normal rubber band. I used one to fix the same issue with my Denon drr-m30 and it is significantly cheaper than the 10 pound option.
Posted on Jan 03, 2014
    Genius:
  • Denon Master
  • 1,550 Answers
If the casete player got some belt change him
Posted on Sep 18, 2008
Denon DRR-M30 cassette tape deck
Either there is a part that is broken or the cam system is needing work to allow it to turn- I would have to look at the unit to give any further detail on what is wrong with it.
May 26, 2014 | Audio Players & Recorders
Cassette player wont play
hi ya
this is quite a common issue with tape head cleaners, try loosening the tape a little, and see if this helps,
Jan 14, 2014 | Jwin JC-13 Wet/Dry Cassette Player Head
My cassette keeps on ejecting so i am not able to play my tapes
http://www.fixya.com/support/t12006246-ive_got_denon_drr_m30_keeps_poping_back
The solution from AlecBrown133 above fixed the same problem for me. The only comment that I would add is that the same repair can be done with a normal rubber band. I used one to fix the same issue with my Denon drr-m30 and it is significantly cheaper than the 10 pound option.
Dec 23, 2013 | Denon DRR-M30 Dual Cassette Deck
Hi ive got a denon drr-m30 it keeps on poping the back out
The solution from AlecBrown133 nails it. The only comment that I would add is that the same repair can be done with a normal rubber band. I used one to fix the same issue with my Denon drr m30 and it is significantly cheaper than the 10 pound option.
Mar 12, 2012 | Denon DRR-M30 Dual Cassette Deck
Hi. I have a much-loved Denon DRR-M30 cassette deck but cannot get the system to recognize a tape. When I close the door it whirs for a bit then just reopens. There was no obvious cause and the unit has...
Hi. I had a similar problem. Remove the casing and you will see a rubber belt on the left hand side which looks like a miniature car fan belt. Even if it looks ok, the likelihood is that it is now slack and not operating properly. Its purpose appears to be to drive a white plastic cog wheel which secures the tray in position ready for the cassette to play. If the tension is insufficient to lock the tray, it automatically ejects after a couple of seconds of the whirring sound you describe. Contact Charles Hyde & Son Ltd of York who are main distributors for Denon and order part number 7790031, called a tray loading belt. The Sales number is 01759 303068 and that takes you right through to someone who will process your order; the part costs about £10 incl postage. They sent the part the day after I phoned - great service. It takes a few seconds to remove the old belt and replace it with the new one. Good luck
Aug 01, 2011 | Denon DRR-M30 Dual Cassette Deck
I have a Sony Handy cam DCR-HC30. When i put a cassette in, it says (reinsert the cassette).
-make sure that your tape is clean and dry
-clean the tape head inside the tape deck if you have a video head tape cleaner
*tape head: the one that reads the tape inside the camcorder.its the metal thing at the bottom inside the tape deck.
-or you can use a soft and dry Q-tip to clean it(dont use any liquid cleaners)
*or if confused where the tape head is....just clean all metal parts inside the tape deck and make sure you do it lightly with a soft dry Q-tip.
Jun 05, 2011 | Sony Handycam DCR-HC30 Mini DV Digital...
Tape stuck
HELLO
Go to Audiokarma.org on the web. The guys on there are brilliant and I'm sure someone may have the answer. You will have to register to post your problems - it's worth a shot!
Apr 26, 2010 | Denon DRR-M30 Dual Cassette Deck
Cassette player is eating tapes
Hey there.
Cassette head cleaners generally only improve the sound quality on playback. This problem sounds more like something mechanical; I would open the player and check out the capstan and rollers. If they are dirty, clean them with a mild soap and water solution, (carefull to not get it too wet). Also, as for the tape deck in your vehicle, OEM systems are notorious for eating and destroying cassette tapes.
Let me know how this goes over,
HortonA!
Mar 22, 2009 | Audio Players & Recorders
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
