What causes compressor terminals to blow out?
    Problem Solver:
  • 15 Answers
There could be several causes, but the most common are these two..
1. Loose connections to the terminals.
2. Over-amperage on the terminal.
Posted on Sep 18, 2008
Compressor not running
id try a new capacitor (cheapest solution) , but sounds to me that your compressor is done for. id bet the evap coil is quite dirty , this is a usuall cause
Jul 21, 2015 | Haier ESA412K 12,000 BTU Energy Star...
Why does it pop the reset button?
The button is a current overload protection for the motor. There is a variety of causes. Defective motor windings, carbonized burnt pressure switch contacts, loose connection (e.g. cord to plug, switch terminals, motor terminals), wrong voltage supply to the motor, worn motor bearings, drive belt too tight, or defective driven machine.
I would run the motor with no load, remove the belt or coupling to the compressor pump, and read the amperes and compare to the motor nameplate rating, let it idle a few minutes and listen for bearing noise. By reading motor amperes or current while the compressor is still connected to the motor, it can be determined if the reset button/overload protector is weak. Check every electrical connection for discoloration or overheating and repair if any are found. Check the contacts of the pressure switch. If nothing wrong is found and the motor is just overdrawing current or amperes, then it is time to replace the motor, probably due to a weak or defective motor internal winding.
May 27, 2015 | Air Tools & Compressors
Duo therm a/c turns on blows cold after a few minutes it trips breaker on the power source
Take off the to the compressor it sounds like a burned terminal is causing the breaker to trip
Jul 26, 2012 | Dometic Rooftop RV Air Conditioner
IN DOOR FAN WILL BLOW BUT NOT THE COMPRESSOR
What I would do is see if maybe a terminal on the compressor is burnt. Easy fix. Looked up the model number to no avail. If you have separate capacitors for fan and compressor I would look for a swollen failed capacitor. Check and see if the compressor termials all have continuity with each other. If you read an open circuit between any 2 terminals on the compressor then the compressor is shot
Jun 11, 2012 | Fedders FPTHP15B208 Cooling Packaged...
The 3 amp fuse on the control board of my furnace blows often when the heat comes on and immediately when the A/C comes on. I got a new thermostat. Can the blue and yellow wires for the A/C be switched...
Yes if the wires are on the wrong terminals the fuse will blow.
Also any short circuit of any wire will cause the fuse to blow.
The yellow wire is typically for the compressor contactor to engage.
The blue wire is typically a neutral wire.
If blue is touching any other wire and it is the neutral wire the fuse will blow.
Oct 17, 2010 | Heating & Cooling
Air is not cold
the fact that the compressor light is coming on tells me power is being sent to the compressor.
if that is true then there is really only 2 possibilities.
1) you have a wire (or maybe 2) burnt away from the terminal(s). To repair this is fairly simple for the service tech but somewhat complex for the inexperienced, so I won't go into here - but if this is the problem you can probably (with a little expert help) fix it yourself.
2) the compressor is not starting even though voltage is being applied to it's terminals. Usually this is caused by the compressor being 'electrically open,' and there is nothing that can be done except to change out the compressor.
good luck!
Apr 22, 2010 | Amcor AF9000E Portable Air Conditioner
My compressor stoppped running. i found a burned out fuse inside. i've replaced the fuse. the fuse was labeled 3a250v. thats what i replced it with. when i turn it on the fuse blows immediately. on some...
Every time I connect my Campbell & Hausfeld fp200300av Compressor and push the power on, the fuse blows. Even if I disconnect the motor from the circuit board the fuse continues to blow. Then I extracted the Rectifier-diode (the black and square with a hole electronic with four stands part).
This piece was the reason of the short circuit, I replace it with an equivalent one and I accomodate it to the right terminals in the circuit board. My compressor works flawlessly again!
Sep 24, 2009 | Campbell Hausfeld Air Tools & Compressors
Have a hampton bay 24000 BTU AC. Smelled burnig behind control panal. Opened it up found what seems to be an overload switch burnt through.. Leads go to capacitor terminal C & Herm. I changed the...
I checked wiring on my other 17,000 BTU Hampton bay AC & noted there was no overload switch wired into capacitor. So i just removed the burnt out overload switch which was causing a ground & blowing breaker. I noted it was not wired in between the compressor circuit but just attached to the compressor terminal & common terminal on capacitor. I guess it is a sacrafise type device that saves the compressor from burning out on overload. Anyway The AC worked fine with the burnt overload switch removed. It has been runnning 2 days now with no problems. I however did replace the capacitor with a new one. You can use either an oval or round capacitor as there is ample room. Just make sure your cap. values match old one. I will probable try & purchase a new overload switch if possable & install it at a later date, for the extra protection.
Angelo V.
Jul 20, 2008 | Hampton Bay Heating & Cooling
2000 coleman mach
It is possible that the compressor has completley failed and is shorted to ground. The way you check is to access the compressor terminals where the wires hook up. After noting the location of each wire, remove the wires from the compressor terminals. Get a piece of sandpaper and shine up a small area on on of the copper pipes coming out of the compressor. Use an ohmmeter and check for continuity between each one of the compressor terminals and the copper pipe. If you have ANY continuity from any terminal(s) to the pipe, the compressor is dead and will require replacement. If not then check all of the wiring to and from the compressor looking for any possible shorts to ground (wire chafing, cuts, etc.) After that, check the run capacitor for the compressor. If the capacitor is failed, it will cause the compressor to draw locked rotor amps. Generally speaking, the quick way to tell if it is a capacitor or a short is to listen to the unit. If it trys to start for a couple of seconds and the pops the fuse, either it is the capacitor or the compressor is seized up. If it trips the very instant that it trys to come on, it is a short.
Jul 01, 2008 | Coleman Mach 15 Air Conditioner
Dead Board on Amana PTC153A50AD
Before the replacement of board please check the fallowing:
- Check for loose terminals and re tight.
- Check compressor terminal post if terminal clips are tight.
- Check compressor resistance and terminal to ground resistance. And check your compressor is not stuck up.
- Check indoor and outdoor blower motor if not stuck up by rotating it with your finger, if it rotates freely then its ok.
- Check the resistance of both indoor and outdoor fan motor resistance and line to ground.
- Check your voltage supply if normal.
- Check the compressor and blower motor capacitor if good.
- Check the unit supply wire if not discolored.
- Check the terminal of your circuit breaker if tight.
If all of the above are ok then it is safe to replace your unit with new board
May be poor contact of the said relay may cause the blowing of your board. Volatage fluctuations is also the suspect or damage solder of the board due to heat.
Jan 21, 2008 | Amana PTC153B50AJ Electric Heat Air...
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
