Question about Epson Stylus CX6000 All-In-One InkJet Printer
Scan functionality problems.
Whenever I try and scan to the computer (using either the Epson scan program alone or with photo editing software such as Photoshop) it gives the following error message: "escndv.exe has encountered a problem and needs to close. We are sorry for the inconvenience."
Also, it will not scan by itself without use of a computer - if I try and do a direct copy, I can hear the scanner running, but it "prints" a blank page.
Epson support is absolutely useless - everytime I email them about the issue I get some sort of automated response with fixes that don't seem to me like they are addressing the real problem. The first solution was to reinstall the drivers which I had tried long before I'd ever emailed them... and the second was to go into the Windows Registry and mess around with files - I'm just not computer savvy to feel comfortable with that.
Not to mention the fact that it's not scanning on it's own screams of a problem with the unit itself, not with my computer.
Thank you for any help you can give!
I have a problem error 90 for Epson stylus CX6000 All-in-one Printer
Posted on Oct 11, 2008
Scanning - When I scan a photo, how can I then access it. I have Picasa 3 software
When you scan a photo or document, the computer will need to save the new document somewhere on the system. You should determine (before the scanning process) where that document is being saved and what name it is being given.
Jun 23, 2016 | Epson Office Equipment & Supplies
How can i use epson px660 3-in-1 printer to photocopy a document
You can scan it by selecting the following functions on the control panel. Once you scan it, then you can print,email or save the document. The Scan to PC function lets you automatically scan your original and save it as a JPEG file on your computer. The Scan to E-mail function lets you scan and attach the image file to an e-mail message. The Scan to PDF function lets you automatically scan your original and save it as a PDF file on your computer. You can also assign a program to scanner function on the control panel. The online manuals are on the bottom this link: http://www.epson.eu/nbsp/Printers-and-All-in-Ones/Epson-Stylus-Photo-PX660/Drivers-Support;jsessionid=AC659B8B8326865BD44BEE3113515C91.acc7-new
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 21, 2011 | Office Equipment & Supplies
I need to scan A document using an epson RX425 printer how do I do it #
It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at epson.com for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
I hope this helps.
Jun 10, 2010 | Epson Stylus RX425 Multifunction...
How do i scan something and then have it shown on my computer so i can edit it ?
You will need to use Optical Character Recognition software such as Abbyy Fine Reader. Most scanners are supplied with software to allow this. You have to use the OCR software and then save or export to word. If you do not have any OCR software then free software can be downloaded from www.simpleocr.com
Jan 15, 2010 | Epson Office Equipment & Supplies
I have escndv.exe error problem with 4490 scanner. I've reinstalled the drivers and it still comes up
The first thing to try is uninstall the Epson Scan. Via either the start
menu item if one exits or from the Control Panel Add/Remove Programs.
Reboot computer.
Install the latest driver from the epson web site -
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=50666&infoType=Overview
Latest is 2.68A for WindowsXP, etc.
You should go ahead and download a fresh copy from the web, your copy may be
corrupted.
After the install, reboot.
If that does not solve the problem.
You got to go deeper.
Remove the Epson scan. (again).
Backup your registry.
Edit the registry and remove all references to the Epson Scan.
Remove the folders and entries for Epson Scan in \Windows\Twain_32\
Reboot:
Install Epson scan.
Good Luck!!
Jul 03, 2009 | Epson Perfection 4490 Photo Scanner...
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
HOW DO YOU SCAN?
You need some sort of photo editing program such as MS Paint or Paint Shop or any other imaging software. Open the program and click on Import. It will ask you which device or which TWAIN device you'd like to import from. Click on your scanner and you should be able to start scanning.
Apr 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Scannning photo
I hope you get this message when you are trying to scan fom the All-In-One stand alone machine itself and windows operating system...?
If then follw these steps mentioned bellow:
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center/HP Director) Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Sep 28, 2008 | HP Officejet 4355 All-In-One InkJet...
OCR
To scan a document for editing purposes, you will need OCR (Optical Character Recognition) software. OCR software is not included with your model.
OCR software interprets the scanned document for editing purposes. The Epson driver alone only scans documents as image files and is not capable of this interpretation.
Some reputable OCR software programs on the market are:
Omni Page Pro
ABBYY FineReader Pro
Presto! OCR 4.0
Please understand that Epson has NOT tested our products with these programs. They do not know if these programs are TWAIN compliant and will import directly from our scanners. I recommend that you contact these companies for full compatibility information if you are interested.
Jun 01, 2008 | Epson Stylus CX9400 Photo Printer
How do I get the scanner to work?
You need to either use the software that came with the scanner (if you got any) or if an older scanner that only provided drivers, then, for images, use any photo editing software and look for an Import from button - select TWAIN and your scanner and/or then look for an Acquire button if available - some programs automatically start scanning once you select the scanner, others like PaintShopPro require you to then Acquire the images. Many other photo editing programs just have an Import from scanner option.
You mention a printer as well - is it an all-in-one?? I've an Epson AIO but the software that came with it, allows me to choose whether I want to import the image to the PC or print it out - you may need to check your manual if you have one or search online for info about your model.
(If you want to scan documents try scanning them through Adobe if you have it, or search online for some other text importing type software programs that are free and will work quite well.) Hope that helps? Romayne
Apr 21, 2008 | Office Equipment & Supplies
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
401 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
