Question about Archos 604 Digital Media Player
My archos player does not reset it is frozen when i select recovery nothing happens
  • fixarchos604 May 11, 2010
    Which recovery mode? If it is #2, you may need to open the unit and check that the ribbon cable is still connected to the Hard Drive.
    Mine is stuck in Recovery mode 1 or 4, depending on whether or not I press the 1st function button just after the red light for the Hard Drive comes on.
    Recovery Mode 1 -- press button just after red HDD light
    Recovery Mode 4 - turn on the unit
Try undoing your battery for a couple of seconds and then try again. Have had the same problem and it seems to work for me.
Posted on Nov 02, 2008
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
Feb 17, 2011 | Archos 405 Digital Media Player
My archos 3 vision screen has frozen how do i fix this problem
press the reset button in the back with a pin or small pen, hold for 10 s or so.
May 20, 2010 | Archos 3 Vision Digital Media Player
Hi my archos 3 vision is frozen, how do I get it going again
Hi
My Archos 1 Vision. Wont play a particular music file. It has played it amazingly fine since i bought it 3 months ago. It was connected to my computer charging for a while, then i turned my system off so it was off for a while.
Wanted to listen to a few songs before bed,turned it on,selected Music,Scrolled down to the file i wanted,Went to select a song.........FROZEN! I can turn it off but the same thing happens everytime i go to select something from this file
Please help i need music on my travels ;-)
Feb 19, 2010 | Archos 2 Vision MP3 Player
Archos 404 is stuck in recovery(code2)
Do not pick any options just reset the device first. from the liitle reset button under the device with a paper clip.
May 17, 2009 | Archos 404 Digital Media Player
404 is frozen
In the event that your ARCHOS device freezes operation
(due to electrostatic phenomena, for example), you can reset it
by pressing the button for 15 seconds.
May 04, 2008 | Archos 404 Digital Media Player
Archos 404
Choos 'Repair disk' while connected to your computer, then go onto www.archos.com go into support, downloads, choose your model and clck on download archos..... Then go into my computer click on the archos device after that has finished downloading and drag that file into the archos folder and the rest it does itself.
Mar 15, 2008 | Archos 404 Digital Media Player
Frozen
reset button is next to data port. use paper clip,press hold.it should reset.
Feb 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
Cannot play any movies
A couple of procedures you can try:
1. Do a soft reset. Press on the power button for about 15 seconds;
2. Do a full/hard reset by removing the batteries and pressing the master reset button;
3. Do a Systems Recovery by powering on and immediately press/hold the TV button till Recovery Mode is displayed. Follow on screen instruction of Forcing Touch Screen Calibration. You may need also to format the internal HD but that would mean you loose whatever data is inside.
If the above is not corrective, it is possible that as you posted it may be a hardware issue. Some users have reported serious hardware or firmware problems with the 704 that would require replacement by the manufacturer.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 15, 2008 | Archos 704 WiFi Digital Media Player
Archos 605 wi fi fault
have you tried resetting the machine on the bottom their is a tiny hole put a reasonable sized safety pin through that you use for a babys nappy.I found this reset my archos!!!!
Nov 20, 2007 | Archos 605 Digital Media Player
Archos 604 Digital Media Player Logo
65 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
