Question about Acer Computers & Internet
Have made some space in D Drive by deleting all back up files
  • David Friesen
    David Friesen May 11, 2010
    Sounds good. What would you like to do next?
    Master:
    Sergeant:
  • 449 Answers
Hi!!
back up all of your files and then try format your drive D:
transfer into drive c:
and then format it
and then your back files transfer to D:
try to email if you have problem it
ronaldsuboc@gmail.com
Posted on Sep 18, 2008
Is it ok to defragment my 2T goflex portable hard drive?
Yes. Defragmenting simply takes the pieces of empty space on the drive and groups them together. When you delete data from a drive or it is deleted as part of a program's function (such as deleting files only needed during installation) it leaves a blank space, but files are lined up on the drive. So if the files are like so:
2GB File ' 3 GB File ' 5.5 GB Free Space ' 1.5 GB File ' 4 GB Free Space
Then defragmenting would try to rearrange the files like so:
2 GB File ' 3 GB File ' 1.5 GB File ' 9.5 GB Free Space
So, in short, yes, it's okay to defragment your drive.
Mar 08, 2013 | Seagate FreeAgent GoFlex Desk Desktop...
I accidentally deleted the gmapprom.img file from my nuvi 710. Tried to put it back and was told the is not enough disk space???
It may be because you deleted the file, but it's still in the Recycle Bin (still there taking up space until you clear the Recycle Bin). By your trying to reinstall it, you are essentially adding a second copy and running out of hard disk space. Try double clicking the Recycle Bin and click your image file then click "restore this item". Note however that your almost out of space on your hard drive. Try clearing out the junk. Delete as many file, esp large video and image files, as possible.
Then clear your Recycle Bin and then delete all your temporary Internet files. (In Windows XP it's Start, Control Panel, Internet Options and check Delete. When you get the pop up, check everything you can live without).
Then defrag your hard drive. In Windows XP, open Explorer (right click Start, choose Explorer), goto My Computer, highlight your drive C, right click, choose Properties, click Tools and then "Defragment Now". Could take over an hour if your drive is near full.
Depending on how much you are willing to trash, you could be back in good shape in no time. As a bonus, you should notice your computer running much faster after this.
Jun 19, 2012 | Garmin NUVI 710 Car GPS Receiver
HOW TO RECOVER THE DELETED FILE IN THE HARD DISK DRIVE
That's easy, much data recovery software can solve your problem.I recommend you have a try of Wondershare Data Recovery,This program is equipped with four critical modules:"delete recovery", "format recovery", "partition recovery" and "raw recovery". It can help with your case.
Jan 11, 2011 | Sony Handycam DCR-TRV33 Mini DV Digital...
My drive c is full and drive d is empty on acer aspire 5633 wlmi what can i do
If your recycle bin holds any unnecessory files deleted previously, clean it. A file deleted normally goes to the recycle bin and doesn't give you back the space it holds. Thus to free that space you need to clear the recycle bin.
If the above method is not helpful open my computer right click your C: drive and click properties. You will find a disk Clean up button near the usage pie chart graph click it. It will calculate space to be cleaned and a disk clean up window appears in the files to delete list box select your choices. At this stage if you don't need your previos restore points except for the last one, it would free more space. To do that click on the more options tab at the top of the form and at the bottom you will see system restore. Click the Clean up button and confirm your action. Wait a while the buttons might not be responive at most for a minute depending on your computer's speed. Now move your mouse over the Ok button if it is active click Ok. This will give you some space back.
Otherwise Back up your files to the D drive first. What you do is copy the files from where you stored them to the D drive first. When done copying Delete the files on the C drive using Shift Key + Delete. ( I prefer copying than moving the through the cut command, because if in case the operation aborts in the middle of the process of moving, you will find it very hard to keep yor folder organizations as they were.
Nov 22, 2009 | Acer Aspire 5633WLMi Notebook
How can I recover deleted files
so long as the file has not been overwritten there are many utilties available free that will accomplish this. I have not made this mistake in awhile so i cannot tell you the best current program, but I have used this one before
http://ntfsundelete.com/ and it is quite nice. Keep in mind if you have continued to use the drive and the space that file occupied has since been overwritten you will not be able to recover it.
Oct 29, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Cannot delete files from D drive
Try deleting the files inside the folder first
If not
Copy some of the files off the drive onto a DVD or two that will make working space on your hard drive
Jun 25, 2009 | HP Pavilion DV2740SE Laptop
Can't Delete Files From Global MP3 Player with Mac OSX
When moving an item to the trash, it actually is just in a hidden ".Trash" folder on that disk, so no space is actually freed up. Can you try hooking the drive back up and then emptying the trash?
Jan 18, 2009 | Global Marketing Partners V3-8B512G (512...
Non ntfs problem
One possible work around
Provided you have access to another PC and feel comfortable with taking your hard drive out of your PC and putting it back in
1. buy a USB external hard drive enclosure and install your hard drive into it
2. connect this USB hard drive to another PC
3. create some free space by deleting some files (see Safe files to delete below for details)
4. reinstall hard drive back into your PC and try to boot normally
1. temporary files - on Win XP these are normally in "C:\WINDOWS\Temp"
2. temporary internet files - on Win XP these are normally in "C:\Documents and Settings\[Your Username]\Local Settings\Temporary Internet Files"
3. other temporary files - on Win XP these are normally in "C:\Documents and Settings\[Your Username]\Local Settings\Temp"
Note that if you have more than one user account on the PC, then each user could have files that are safe to delete in the folders mentioned in number 2 and 3
-Magnon
May 24, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computers & Internet Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
