Question about Mitsubishi PD-5050 50 in. Plasma HDTV
Mitsubishi PD-5050 Tv is hooked into surround sound system. I have audio but no video. Any suggestions? Thanks, Veronica
SOURCE: Mitsubishi VS-8087
There are L and R audio outputs in the rear, so you can hook it up to a surround sound system; no optical outs.
The screen size is 80 inches - but I'm sure your friend told you that.
Posted on Nov 25, 2007
MrBob84
  • 90 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Posted on Feb 13, 2008
  • 25 Answers
SOURCE: help hooking up tv to surround sound system with dvd player
with my Ws-65513 I run only right and left channel down to the aux from there your dolby 5.1 should doe the rest .most systems have center (speech) (R.front) (Lfront)(R.rear)(L,rear) and SW .center you want on the bottom or the top of your screen ,The SW you want Ever behind your set or under your couch.LEFT AND RIGHT REAR YOU WANT SOME WHERE BEHIND YOU OR AT LEAST 90% TO WHERE YOUR SITTING NOW THE FURTHER YOU SET THE REARS BEHIND YOU THE MORE DELAY YOU SHOULD HAVE ,THERE IS AND ADJUSTMENT SOME WHERE BETWEEN 10-30 MIL-A-SECONDS THIS GIVES A SLIGHT ECHO FROM FRONT TO BACK..
i HAVE AN AIWA AMP RUNNING A 12INCH FISHER,CABINET BOSE,AND A PANASONIC SUROUND AS MY FRONT, LEFT AND RIGHT STACKS.WITH A JBL CABNET AND PANA CENTER FOR SPEACH .THEN LET THE REAR GET BOOSTED WITH THE PANA SUROUND SYSTEM BECUASE i NEEDED AT LEAST ANOTHER 120 WATTS TO RUN THE THE JBL12,WITH A PANA SUROUND AND A SUPER TWEET WITH A I/2 POUND MAGNET AS MY L AND R REAR,
THE ***** IS WHEN IM RUNNING MY LOWLY 44 DOLLOR PHILLPS WITH A SEMI 10801 ,I CANT GET MITS SPEAKERS ON LINE,THERE IS ONLY ONE INPUT.wHAT YOU REALY WANT TO DO IS HAVE NO DELAY ON THE CENTER,THEN 5MIL TO YOUR MIT SET SPEAKERS.YOU WILL GET AUTOMATICLY IF YOU SET THE TV ON SURROUND,PUT ONLY KEEP AT 1/4 VOLUME OR YOU WILL SCREW UP THE WHOLE EFFECT HAS THE JUICE GOES TO YOUR LEFT AND RIGHT FRONT IT NATRUALLY HAS ANOTHER 3-5 DELAY AND SET YOUR REARS TO A LEAST 20 TO 30 MILL DELAY.iT WILL PUT YOUR LOCAL THEATER TO SHAME.
Warning make sure all your wires are in phase +to possative -to neg not only you get a ping pong effect if you plan push a lot of watts a surge could make you have a very bad day ,most wires are eather colored on the outside or silver or gold on the inside.if you plan on moveing one side away from the compared to the other side its better to increase at the gauge of the wire,or you will never get the balance right and end up throwing your equipment at whatever pissed you off in th first place.
it,s a type of balance of chi ONCE YOU HAVE IT RIGHT,ANY ONE OR THING THAT ENTERS YOUR SPACE WILL NOT BOTHER YOU AS LONG AS TUBES CONVERGE AND SOUND IS
TUNED LIKE A FORK AND IF SOMEONE ***** WITH YOUR SYSTEM THE TUBE IS SO BIG
YOU CAN AT LEAST FIT ONE BODY IN IT ,i THINK THE CASTORS CAN AT LEAST STROLL YOUR PROBLEM TO THE LOCAL LAND FILL.
i KIDDING PUT i LOVE MY SET ,.i WOULD LIKE TO KNOW IF THE NEW BLUE RAY WOULD CLEAN UP THE 1080i ANY BETTER. GOOD LUCK
Posted on Feb 08, 2009
SD Tech
  • 14553 Answers
SOURCE: how do we turn off the internal speakers to use a
IF it is a Mitsubishi WS-55613 rear projection set---
You with the Mitsubishi remote go into the customer menu and select Audio(it should be a separate item) and look for a setting for speakers--right cursor to it and up or down cursor to change it.
Some models may have this feature in the SETUP part of the menu.
if you have questions or need help let me know--I am here to help people.
If this information helps rate this solution as I do this here for free.
SD TECH
Posted on Nov 05, 2009
  • 7 Answers
SOURCE: I have a 52" mitsubishi
go into the menu and go to audio/video should be able to set your audio from there
Posted on Dec 11, 2010
Mitsubishi PD 5050 does not show HDMI
I have a client with a PD 5050 that just stopped recognizing HD signals through HDMI and component. It does seem to accept a standard composite signal. We replaced the TV. They had me haul away the old one, and I'm trying to find out if it's worth repairing.
Interesting that it was right around the date you posted this question. I bookmarked this page to return if I find out anything.
Nov 14, 2011 | Mitsubishi PD-5050 50 in. Plasma HDTV
We are trying to hook up our 65" Mitsubishi DLP TV to our JVC surround sound...basically we can get the DVD to work with surround sound but when we have the tv on our sound doesn't come out of our...
That cable doesn't exist. You can't just shoot electrons into one end of a copper cable and have light come out the other end.
My $.02...
Treat your TV like the primary user of the Hi-Def Video ONLY, not the source of any audio. Ask yourself, does it really NEED to be in an audio chain if it doesn't tune the station off the air?
Your JVC should be the primary destination of high-end audio, directly from, say, the Cable Box' while the Hi-Def video is sent to the TV.
Zigzagging good audio and video through the room to devices that don't need it is expensive and wasteful, plus it adds complexity and unnecessary connections that add nothing but could fail.
Feb 15, 2011 | JVC THD-50 System
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
I just bought the 52 inch philips lcd tv model number 52pfl3603d. I'm trying to hook it up to my philips surround sound model hts3544 so I can hear the tv thru the surround sound. Watching a dvd is no...
Is the volume on the dish network device turned all of the way dowm?
Is the dish network connected to its pwn input on the SS system and did you turn the SS system to that input ?
Are you using the analog input (red and white) cables to the input from the TV to the SS System?, not from the SS box? This is not the correct setup?
Sep 25, 2008 | Philips Audio Players & Recorders
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
Feb 03, 2008 | Pioneer HTS-GS1 Theater System
Connecting surround sound system
get a reciever and then get componet cables then hook it all up through the hdmi cables
Jan 22, 2008 | Sylvania 6727DF TV
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Mitsubishi VS-8087
Nov 18, 2007 | Mitsubishi VS-8087 80" Rear Projection...
Mitsubishi PD-5050 50 in. Plasma HDTV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
