Question about Xerox WorkCentre M118 Black and White Copier
Need help hallo gays am having trouble with a xerox 5825 which is showimg me error J3 and i really don't know how to fix it right,
    Problem Solver:
  • 7 Answers
Hi
you havenot installed drum cartridge properly inside the machine or you have installed the drum cartridge of Xerox 5816/5821.
Hope you will do it.
Posted on Sep 20, 2008
NEED TO KNOW HOW TO DISASSEMBLE VACCUM HOSE TO CLEAN DRAPERY
you don't really need to know that. just go ahead and buy a new one.stop being so gay.
Dec 14, 2011 | Vacuums
I have a 2002 jeep grand cherokee limated,the blower motor resistor wireing shorted out at the plug connection the control circuit to the resistor,I need to know the color code for the j1,j2,j3 termals on...
I've seen a few of these and the easiest fix is to replace both the blower motor speed controller/resistor and the wiring harness connector. I've tried fixing the connector but the repairs don't last because of the heat generated at the connector if everything isn't just right. You can purchase the connector, which comes with color coded pigtail wires attached, from the dealer and it's a fairly easy and permanent fix. Hope this helps and good luck!
Aug 10, 2011 | 2002 Jeep Grand Cherokee
Xerox wc pro 420 is showimg E6
your side or front cover is not fitted well or the sensor doesnt actuated well check it out
Jan 21, 2011 | Xerox Office Equipment & Supplies
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
J3 error On Xerox WorkCentre Pro - 215
A J3 means the toner cartridge is not compatible. That is the what the J3 message means.
Make sure the correct cartridge has been installed. For example, a Pro16 Toner Cartridge looks very similar and will fit in the machine, but it will display a J3 fault. Install a known correct Toner Cartridge if you suspect the cartridge in the machine is the problem. If the wrong Toner Cartridge has been used, the correct cartridge needs to be ordered and installed in the machine
It is possible the chip on the back of the cartridge is bad. Have you tried reseating the cartridge? Maybe it is just loose.
Dec 19, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Reset Xerox Copier Machine model No. 5825
your copier should be displaying a fault code, different codes need different reset codes - be specific
Jan 05, 2008 | Office Equipment & Supplies
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
Xerox WorkCentre M118 Black and White Copier Logo
142 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
