Question about Mitsubishi WS-65809 65" Rear Projection Television
Great Picture But No sound
My Mother In-Law has a 2002, 1080 HD, Rear Projection,65' Mitsubishi TV. She has no cable just roof antenna. coaxial input. I recently programed her TV to received over the air digital channels. Great Picture in HD but no sound. I switch over to the anolog atenna input get picture and sound. Im really good with electronics, went over the manual and every sound option on the setup and menu on the TV. I have never came across this before and I hook up alot of TV's for my friends, and I have to hook up DVR, DVD Surround Sound & Game Console. Please help me so I can get My Mother In-Law off my back.
  • regissreg Sep 18, 2008
    My Mother In-Law has a 2002, #WS-65511 1080 HD, Rear Projection,65' Mitsubishi TV Model . She has no cable just roof antenna. coaxial input. I recently programed her TV to received over the air digital channels. Great Picture in HD but no sound. I switch over to the anolog atenna input get picture and sound. Im really good with electronics, went over the manual and every sound option on the setup and menu on the TV. I have never came across this before and I hook up alot of TV's for my friends, and I have to hook up DVR, DVD Surround Sound & Game Console. Please help me so I can get My Mother In-Law off my back.
  • regissreg Sep 20, 2008
    Thanks for Helping but The antenna is connected to the ANT-DTV input, but thanks for trying.
  • 927 Answers
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Posted on Sep 20, 2008
Why does my Mitsubishi WD-65737 TV go black for 4 or 5 seconds then picture comes on again with the top left corner says "Cable Box".
Replace service cords, as they might be getting worn and loose. It does sound like that to me. Bad coaxial cables
Apr 10, 2015 | Mitsubishi WD-65737 65"" rear projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Tv picture
A problem with your inputs maybe. Find honest TV tech.
Oct 27, 2013 | Mitsubishi WS-65869 65" Rear Projection...
There is not reception. Antenna A failed a year a go, I switched to Antenna B and now is not working either. When I connect Cable (COX) antenna inputs, A & B, do not detect it. My TV is a Mitsubishi...
Check if the video /audio input( AV) works ok.If so the tuner inthe set is defective and must be replaced.
please replace one to confirm after checking the +B voltage on the tuner being present.
Sep 12, 2010 | Mitsubishi WS-65513 65" Rear Projection...
I have a 65 inch Mitsubishi rear projection HD TV. The screen went blank today. I have cable hooked up to the componant input and I get no sound or audio. If I hit input a few times I get static sound...
Does the input menu appear on the screen when you press input? If so its probably the IC Regulator 9v supplying the video board. If the green light on the front is blinking then powering off it is one of the 7 capacitors and you should just replace them all, 30-35 bucks. If the power stays on and its just your video isnt coming on(audio as well) it is the IC Regulator. Mine called for the part - BA09FP IC REGULATOR 9V It is about half the size of a pinky nail and located directly behind the video input board in the back of the tv. It has two prongs on the left side and one wide tab on the right. It solders directly to the top of the board and not through it. It says BA09 on the chip. This fixed the problem for me.
Aug 16, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Can't seem to add HD channels to Mitsubishi WS-65513
You need to run an external antenna feed to the air DTV input jack, bottom left. You can use your loop out if you already have an antenna connected to your antenna A input jack. Create a DTV device, then run your antenna setup for DTV.
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Hoe to set my tv to hd
You don't set your TV to HD, you connect an HD source to it via either a component input or HDMI or DVI connection. I fyour TV has its own HD tuner, then you'll need to connect a good antenna or cable system to it.
michtech
Feb 19, 2009 | Mitsubishi WS-65315 65" Rear Projection...
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
How to see local channels in HD with a traditional antenna?
If your set does not have an ATSC tuner, for HD, then you need to be using a suitably equipped STB.
Your satellite STB - box - should take in OTA channels and display them as part of its normal operation, tho. It takes in the antenna signal from your roof antenna and displays the HD version of your OTA channels, if it is an HD STB, along with the HD channels it gets from the satellite overhead.
Mr Bob
Dec 19, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi Vs-6071 Picture
replace the signal board (one with all the rca's on it) and not the main board if a plain antenna works OK
Jun 05, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
376 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
