Question about Lexmark C510 Laser Printer
Error message - close front door
We have moved the printer and have got the above message. all doors are closed.
  • Anonymous Dec 01, 2008
    I checked all the doors, they are closed. error message still says close front door.
5 Suggested Answers
BondoFox
  • 40 Answers
SOURCE: Fuser Door/s
Your Samsung ML-3561ND looks to be an HP Laserjet 4000-series printer. Same engine, different electronic. The fuser is in the rear of the machine, and may be relating to the drop-down rear panel where you clear paper jams. Open it and give it a good push closed and the printer should cycle and come ready. Let me know what happens!
Posted on May 29, 2007
Scott Ellin
  • 558 Answers
SOURCE: Error notice
Please reboot the Printer then check
Again reboot the Printer and PC both and then check. Let me know if the error still persists.
Regards
Ellin
Posted on Sep 26, 2008
SOURCE: close door or insert cartridge
This repair worked like a charm for me. The little metal piece just pops right in when you take the switch out.
Posted on Oct 28, 2008
  • 113 Answers
SOURCE: Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Posted on Feb 28, 2009
Close door or replace cartridge message won't go away
Replace the imaging drum and reset the life counter on Dell ...
www.dell.com/support/article/us/en/19/SLN142828/EN
DellOct 31, 2014 - Obtain replacement part; Fit replacement part; Reset life counter ...counter on Dell 1700, 1710, 1720, 2230, 2330, 2350, 3330 and 3335 laser printers. ...toner low and error lights, 23xx and 33xx will display the message Replace PC Kit. ...Fit the assembled toner and drum to the printer, close the front door.Missing: 5210n ‎persistent
34 Short Paper Error on Dell 5210n, 5310n Printers ' Dell US
www.dell.com/support/article/us/en/19/SLN133464
DellMay 10, 2013 - If the pegs do not change position, the gray paper size guide may have become separated ... On the left side of the inside of the printer, under where thecartridge goes, there are two white ... Close the upper and lower doors.Missing: laser ‎message ‎persistent
Dell Printer -- Feeder Problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/29793
Aug 28, 2008 - I am having trouble with my Dell 1700 laser printer. ..... the printer jams in the middle, I get the message, but opening and closing the front door will allow the..... I replaced the cartridge just in case,(the tape had been removed!) ...
Jan 08, 2016 | Dell 5210n Laser Printer
Close front door error message on lexmark x342n printer
If you have snapped the lid switch or male end to sensor, you may have to jump out the door switch.
If not, see the attached link for information
May 21, 2014 | Lexmark X342n All-In-One Laser Printer
Close section properly
Its not talking about the bypass tray. Its saying the right side door isn't closed. There is a cover above the fuser that may not be closed. Open the right side door and see if you see any broken parts. If everything is closed correctly and not broken, the message will go away.
Jan 24, 2014 | Konica Minolta bizhub C250 All-In-One...
I have ir 400 machine its front door is close but error is close the front door whats problem
Either you misunderstand this message or the switch which says the door is closed is not doing so.
Nov 15, 2013 | Canon imageRUNNER 400S Copier
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Drum error message appears
open the front door remove drum unit you will 'Blue' liver on the top of the drum just move it in opp. direction and again move to same position, before closing the door press the options button on the key pad you will see replace the drum option press 1 and close the door.
Apr 06, 2011 | Brother MFC-7440N Laser Printer
How to take out the cartridge
Manually slide cartridge to middle of access door, then lift front part of cartridge up and then lift up straight to remove rest of cartridge
Aug 24, 2009 | Office Equipment & Supplies
HI there,
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
FATAL ERROR
your printer is laser printer change toner cartridge right,
you may try
1) Open the front door and remove the toner cartridge.
2) you will see a small round hole near the colour toner cartridge
3) hold a screwdriver in that hole and the carousel will rotate freely. 4) Move the carousel round and remove each one of three cartridges at a time.
set back all cartridge close door.
Jan 29, 2009 | Konica Minolta magicolor 2300DL Laser...
Lexmark C510 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
