I have a samsung DLP model# HLN5065W it has a weird noise by the lamp not sure if its the fan or the lamp? The noise start when the screen turn on and when i turn it off the noise stay for a couple of seconds after the tv is off.
  • Anonymous Oct 04, 2008
    Same
On closer inspection, you'll find the ballancing weights on the color wheel have fallen off because of glue failure. Epoxy the BB's back on where they came off at (there will be a shadow of where the glue was). Save yourself 100-200 for a new colorwheel.
Posted on Apr 16, 2009
  • 51 Answers
The colorwheel..will need to be replaced..part should run around 100$ to 200$ plus labor
Posted on Sep 18, 2008
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I have a 50 inch hLn5065w ,when i turn it on a very lous noise and vibration seem to be coming if your looking at the back of the tv its coming from the right side looking from the back.i know its not a...
Problem is the Color Wheel, Located behind the Lamp .
You will need a Flash Light and Pull Lamp out ,Look inside and you will see Color Wheel.
Color Wheel PN# BP96-00250A Price $82.66
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Feb 25, 2011 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP Model HLP 4663 WX Constant Whining
What you're hearing is the most likely the color wheel if you remove the lamp you can see part of it ...a multicolored plastic disk.It rotates on a high speed motor and make an awful whining noise when it fails.
Rustym62
Apr 30, 2009 | Samsung HLN5065W 50" Rear Projection...
My Samsung HLN5065W turns itself off after about 15 minutes, and all three lights on the front panel flash. The first couple of times this happened, there was a loud muffled sound before it shut itself...
This is a DLP projection that has a ballast and color wheel along with a lamp. The three flashing lights on the front are a diagnostic code. The exact meaning is listed in the owner's manual under troubleshooting. I don't have the manual for your model with me at the moment, so I can't look it up. Since the unit works OK for a while, it suggests that a component is failing under heat stress. This is often the ballast. The ballast is the part that provides the power for the lamp similar to the ballast in a flourescent light. Check the manual for the code and post it here. Also, because your model uses 2 different ballast/lamp combinations, you will need to get the lamp number off of the lamp. Please post that here too.
In the meantime, check the rear area for any obstruction in the air flow. There should be a fan in the rear that needs to be clear of debris and can turn freely. With the set unplugged, try turning hte fan by hand. It should turn easily and continue on its own slowing down to a stop. If it stops suddenly, the fan may be defective and not moving enough air to keep the lamp cool.
Keep us posted.
Dan
Apr 25, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W Lamp won't stay on.
Do you get any flashing lights?  Such as Lamp or Temp?  A common problem with these is the light not coming on.  Sounds like a temperature issue.  When you turn the TV on when it is cool, pull it forward and check the rear on the left to see if you can see the fan turning where the lamp is.
The light system is pretty straight forward:  Power Board -> Ballast -> Lamp.  It is controlled by the DLP Board, though.  Since it is powering up, it sounds like the Power Board and Ballast are okay.  The ballast is used to kick start the lamp on (similar to flourescent lights) but not during normal operation.
Jan 24, 2009 | Samsung HLN5065W 50" Rear Projection...
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Noise from tv
I had the same problem with a 5065. I purchased and installed a new color wheel and that solved the noise problem. The color wheel has a bearing that gets "dry", and when it fails it does sound like a fan bearing.
Jul 10, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
