This problem could be more than just a battery. You may have damaged sensors or case broken. To repair this unit call Frank @ 775-338-6634
The sensors inside the machine is screwed up or the case itself is bad. you can call this number and we can help you with your problem (775)358-2922 look for randy.
SOURCE: Problem with the VeriFone VX570 Credit Card
You can get the Installation Guide HERE.
You need To Install/Replace MSAMs where all previous information is stored:
1 Remove the power cord and/or battery (see Smart Battery) from the terminal.
2 Place the terminal upside down on a soft, clean surface to protect the lens
from scratches
3 Remove the MSAM compartment door screw and rotate the door up and back
to access the MSAM cardholders (see Figure 11).
4 Remove any previously installed MSAM card by sliding the card from the
MSAM cardholder.
5 Install an MSAM card by aligning the card and carefully sliding it within the
guides on the cover until it is fully inserted (see Figure 12).
Contact: VeriFone Systems, Inc.
2099 Gateway Place, Suite 600
San Jose, CA 95110
USA
Tel: 1-800-VeriFone (837-4366)
Main Tel: (408) 232-7800
Main Fax: (408) 232-7811
SOURCE: Verifone VX570 TAMPER DISPLAY
Welcome to FixYa!
It seems that you are having problem with the display of the Verifone. Please try to follow these steps for you to be able to fix the problem.
When the Vx5xx/Vx6xx terminal display screen does not show correct or clearly
readable information:
• Check terminal power connection.
• Remove and reapply power to the terminal.
• Check all cable connections and verify that the telephone line is properly
connected.
• If the problem persists, contact your local VeriFone service provider.
Hope this information will help.
Your response is very much appreciated. Thank you for using FixYa!
SOURCE: TAMPER DEFAULT CERTIFICATE ON VERIFONE
Hi,you need to remove TAMPER through TAMPER recovery tool.
[email protected]
