Tc dosent works on amd pc
Recently i bought a system with the following configuaration
CPU AMD Socket 940 AM2 dUALCORE 4000X2
MD Asus Nvidia Chipset M2 NMX for AM2
the problem is when i am trying to exectute the c programs
the c window is disapperaring and the system is hanging, i need to restart again.
could u give me the solutions for that.
  • 35 Answers
SEE yaar theres no PC problem its surely your TC is corrupted , just try to reinstall tc and work it will get fine. If not then post a comment i will give you the solution.
It does not seems your PC problems its perfect.
Posted on Sep 18, 2008
Cpu
AsRock Support > AlivenF6G-DVI Motherboard > Main Support page,
http://www.asrock.com/MB/overview.asp?Model=ALiveNF6G-DVI
In the list on the left hand side, click on CPU Support List
http://www.asrock.com/mb/overview.asp?cat=CPU&Model=ALiveNF6G-DVI
The AMD Athlon 64 X2 5800+ CPU, (Processor), is part number ADA5800IAA5DO.
Operates Up To a maximum frequency rate ('Speed'), of 3.0GigaHertz, has two L2 cache's of 512MegaByte, and uses the Socket AM2 CPU socket.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Brisbane.22_.28energy-efficient_65W.2C_G1_.26_G2.2C_65_nm.29
In the CPU Support :List it is not shown.
This is ONLY because the Athlon 64 X2 5800+, came out way after the CPU Support List was compiled. NOT because it isn't supported.
No, I have to amend that,
http://forums.amd.com/forum/messageview.cfm?catid=14&threadid=108319
It's because AMD's lack of information, apparently, that AsRock didn't list it.
I don't see the voltage range listed anywhere. (To include AMD)
http://www.cpu-world.com/CPUs/K8/AMD-Athlon%20X2%205800+%20-%20ADA5800IAA5DO.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103274
At any rate let's go with deductive reasoning, and see if this CPU is supported.
1) You can compare the Athlon 64 X2 5800+, to the other CPU's in the CPU Support List; that are comparable to it, and above it.
Don't even have to go too far.
Look at the ADA6000IAA6CZ, and the ADX6000IAA6CZ CPU's.
The two Athlon 64 X2 6000+ versions.
(Doesn't state that, just the above part numbers)
However I DO notice that the ADX requires BIOS version P2.00, and the ADA only requires BIOS version P1.60
(Since BIOS)
2) The motherboard chipset is an Nvidia GeForce 6100 and Nvidia nForce 430, Or Nvidia GeForce 6150SE and Nvidia nForce 430
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#For_AMD_processors
Compatible? Yes.
May need the P2.00 BIOS update, if not already installed.
Regards,
joecoolvette
May 16, 2013 | Asrock Computers & Internet
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
Kind find amd sempron le - 1150 socket am2 (940) driver need help.
You need to know the type motherboard you have (or system) to get the correct drivers. The drivers are dependent upon the motherboard and the chipset on it, not the CPU. If you have that information, I can help you.
Aug 01, 2010 | Intel Motherboard
Can i change my processor? AMD LE-1150 to dualcore or core2duo?
If your using AMD LE-1150 you cant use a dualcore nor a core2duo because the socket of your motherboard is for AMD microprocessor only you can upgrade or change your procs to any AMD AM2 dual core model make sure you check the specs of your motherboard for supported CPU list. you can find that in their website
Apr 27, 2010 | AMD Sempron LE-1150 2.0GHz Processor -...
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
How can i download AMD Sempron Le-1150 Sound Drivers
Cheers
Nov 18, 2008 | AMD Sempron LE-1150 2.0GHz Processor -...
Turboc not working on asus m2n-mx motherboard
Right click on tc.exe click on screen tab check out window instead of full screen under usage options.TC will run in window mode.Then press Alt+Enter to fullscreen.
No solution yet for c graphics programs crash on nvidia chipset.(yeah problem is in nvidia chipset not in MoBo).
Nov 05, 2008 | ASUS M2N-MX Motherboard
Unable to execute turbo c++ on AMD Athalon 5200+ cpu
go to tc.exe icon right click on it then go to properties,click on compatibility tab tick all the options and run on window mode,after starting u cn maximize using alt+enter
Jun 09, 2008 | Hitachi GD 7500 Internal DVD Drive
Can't install a driver
i've lost my driver cd for my asus wl -167g, can i download it for free?
Apr 03, 2008 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
