Dear experts,
I own a macbook pro 1.83 GHz Intel (one of the first releases - year 2006) and I recently noticed some brighter spots located at various positions in the LCD screen. They look like faint fingerprints, but I cleaned the screen several times, and it seems they are due to some LCD defect? The macbook pro is too old for the warranty...
Is there a way to get rid of the spots?
Thank you!!
Rob
If the spots remain in the same place I'm sorry to say no. Be careful what you clean the screen with. I'm a fan of a warm wet damp only rag. Using alcohol or other cleaners may damage the surface. There are also cleaners available at local stores. You don't need anti-static on an LCD display. The spots can be from pressure on the display applied at some point even if that pressure happens when closing or transpoting your laptop.There is no way to fix it.
constant blinking of osd lock and other menu options.besides contrast and brightnessgets adjusted on...
(More)
CONSTANT blinking of OSD lock and other menu options.besides contrast and brightnessgets adjusted on its own.how to solve this?
My 20" apple cinema display has what appears to be interference. Rapid blinking horizontal...
(More)
My 20" apple cinema display has what appears to be interference. Rapid blinking horizontal lines, that slowly move vertically up the screen. They get better the longer it's on, but never fully go away. I have tried plugging it directly into the wall outlet, no change. and it does this when hooked up to either of my macs. Is it dying?
I have a Viewsonic VG2230WM model# VS11422. It has several blown capacitors on the power board an...
(More)
I have a Viewsonic VG2230WM model# VS11422. It has several blown capacitors on the power board an the mossfets show signs of overheating, but they are pretty rugged (will replace anyway). I foind a componant that seems to have overheated and shorted it's at location RT100 just behind the main power connector and fuse F101. What is it? If it is a resistor what is the resistance it should be at? (exterior discolored) Where can I get a wiring diagram? (to findout if you guys don't know)
The Menu section keepspoping . I press the menu button on the bottom right of the screen and after a...
(More)
The Menu section keepspoping . I press the menu button on the bottom right of the screen and after a few moments the menu pops back up and wont go away, ive rebooted unpluged everthing mIcan think off it wont stop coming back up and peventing me from seeing whats on the other side I havea hp w1907 widescreen
