Question about HP Photosmart C7180 All-In-One InkJet Printer
Screen doesn't work
This printer still functions reasonably well. One day, the screen did not function as it did originally. It seems to have power since it is still illuminated but no text or graphics appear. Any ideas or solutions are appreciated.
  • Anonymous Dec 14, 2008
    The same thing happens to mine. I tried the offered solution but it was of no help.
  • 234 Answers
Ry the steps mentioned bellow
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Posted on Oct 04, 2008
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
I kan't enter service mode panasonic 2330
Press the FUNCTION/ORIGINAL SIZE (ledger)/3 buttons in that order, and hold the buttons until all are depressed..Press and hold FUNCTION....then press and hold ORIGINAL SIZE (ledger)....then press and hold 3. The service screen will open with F(x) at top middle of screen.
Oct 11, 2014 | Panasonic Workio DP-2330 Printer
TV Doesn't Function: Can turn on, but no menu or input recognition
the set like all has a hard reset which requires a four digit number code and the original Mitsubishi remote---sets almost everything in the set back to original except convergence.
also, don't buy any TV or electronics on CL as people dump their problems on someone else..
Aug 31, 2012 | Mitsubishi WS-65313 65" Rear Projection...
Screen on front lights up but cant see numbers are functions
Try to re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
If that doesn't help, try to plug the printer to a different known working power outlet in the wall to determine if it's a faulty power outlet issue.
If the problem continues, please contact Lexmark Technical Support Center for further assistance.
Nov 28, 2011 | Lexmark Prospect Pro205 Wireless...
HP 7410 has power, screen is lit, but power button is not. None of the functions (print, copy, scan, etc. will work. Any ideas?
Seems like something a lot of us are experiencing. I have the exact same problem. Has anyone found a solution?
Dec 07, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Can't figure out how to restore the screen
goto control panels then to personalize then monitor settings or display setting and change it there.hope that helps
Nov 25, 2009 | Dell Inspiron E1405 Notebook
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
Flat screen monitor functioning strangely
Sounds like there maybe bad caps on the power board in the LCD. Try a different monitor on your computer and if the known working monitor comes on with the computer and behaves properly then you know its a problem with your original monitor. If the known working monitor acts strange as well then you know its a problem with the video card. Let me know what happens.
Jun 11, 2009 | E-Machines eMachines Desktop PC
HP Photosmart C7180 All-In-One InkJet Printer Logo
62 people viewed this question
Ben Johnson
