Question about Panasonic Heating & Cooling
Air conditioner very loud and not as cool as usual
    Problem Solver:
  • 15 Answers
Two things could be the problem.
The one you might be able to fix is a dirty outside coil. If you look at the outside portion of the airconditioner and notice the coil is plugged up with dirt and lint, all it needs is a good cleaning.
However, if the outside unit looks fine and the coil is not full of dirt, then the culprit will more than likely be a broken discharge valve on the compressor and this is a major repair not suited for the home-owner.
DO NOT run the air conditioner until it's repaired or more (and extensive) damage might occur.
Posted on Sep 18, 2008
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
Window air conditioner loud when compressor kicks in
Possible that compressor motor internal mountings broke.
Apr 07, 2010 | Heating & Cooling
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
Roof air unit too loud inside; quiet outside.
When you say loud, do you mean as in airflow noise, or vibration like noise? I take it this is a ducted system as well. Does it have quik cool option on ceiling assy.?
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Jul 18, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Fan motor has loud screech.
Check for oil ports on motor. Usually red or yelloe plug in caps. No more than 20 drops of oil. I usually use sewing machine oil.
Apr 26, 2009 | Heating & Cooling
Unit making loud squeaky noise
http://www.youtube.com/watch?v=7n5tywSdWKs
This is a cool video with link to applience parts for help and answers
Feb 02, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Jun 15, 2008 | Weather King 10AJA4201AH Air Conditioner
Heating & Cooling Logo
440 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
