I have a JVC DVD & HDD video recorder (DR-MH30S). I use it regularly to record to hd, but cannot dub successfully to dvd. The dvds work in that machine but not in any other dvd players, or even my laptop. Tonight, I tried recording straight to dvd which worked. Just wondering why I can't dub.
  • dayna825 Sep 19, 2008
    Nothing in the link suggested was usable. I have finalised the disks and am using DVD-R, which is the same one that I've burnt successfully straight to dvd. It's just the dubbing from hd to dvd that's the problem.
    President:
  • 1,952 Answers
I have 970b and firmware v1.65 , but anything I put onto disk goes onto a verbatim dvd +rw disk , ready for authoring on a pc ,
Posted on Sep 19, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 19, 2008
    high speed copy may not be work" that you were dubbing from the HD to DVD
    In most cases it is because you are dubbing a show you edited, which
    you think will fit the blank disc, but is actually 2-3 seconds too long
    according to the recorders algorithm. So even though it says High Speed
    Dubbing is OK, when you actually give it the go ahead the final
    internal check switches over to real-time re-encode. You can cancel the
    real-time dub in progress and trash the disc if you want to. Then just
    go back into the HDD recording, trim a small segment of it, and try
    again. You can usually prevent the problem by looking carefully at the
    disc capacity bar at the bottom of the screen just before you OK the
    dub- if you don't see a *noticeable* sliver of black space on the tip
    (i.e. the bar appears to be completely white), you are probably pushing
    it and need to trim the recording by a hair to enable a guaranteed
    hi-speed non-transcoded dub.
    so try to dub with low speed ...
    thanks for using fixya
    have u tried my solution
    Genius:
  • 1,665 Answers
Check when finished recording a dvd if you have select the "close DVD" feature in order to play to any other dvd player.
If dvd is not closed can't play to other dvd players.
Have a nice day.Thanks for using fixya.
    Brigadier General:
  • 6,966 Answers
To my understanding, what you have described indicates that the DVDs that were dubbed needs a last step to enable them to be read in other players as well as your laptop. They have to be "finalized".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 18, 2008
    Master:
  • 763 Answers
Its just maybe your dvd disc cant support what you have made to your dvd player and laptop. in your laptop try to download klite mega codec and install it on your laptop and see if it works. hope that helps!
CHARCOIS
  • 1,879 Answers
Check the infos from this link
    Guru:
  • 1,894 Answers
Are you able to atleast view and play the files in your computer?
if so then there is no problem with the recorder.
what is the format in which it records the files?
  • dewan nafees ahmed Sep 18, 2008
    can you tell me what is the format that the machine uses to record the files??
    because you must be able to view any kind of files in your computer.
    did you try VLC player??
What region code is my jvc DR-MH30S recorder, and can it be made region free? regards Alan
Asuming you bought in the UK it is region 2. There is software to unlock the region code but this was being sold as a CD on ebay and I really can't recommend that you down that route. James
Apr 21, 2010 | JVC DR-MH30S DVD Recorder
Unable to do anything!!!
In what state is the unit? Is everything else functioning asides from what you posted?
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
Jun 16, 2009 | LG DBRH197H DVD Player/HDD Recorder
How do I delete files stored on the HDD of my JVC DR-MH30S?
Use edit on you remote. this will bring up delete
Nov 05, 2008 | JVC DR-MH30S DVD Recorder
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di LOADING...il mio jvc dr mh30..di 6 mese e roto ..ma trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE PRO..free da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto ok...ma io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo 80gb..ma perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di LOADING..se non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro fastidiosa.......se aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ agimqosesda@yahoo.com ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
Dr-mh30s. stops dubbing after a few minutes.
I seem to have sorted this problem for me simply by unplugging power.
I actually left it for nearly a week before plugging in again, but I'm sure a day would do, probably less.
Dubbed 2 playlists since, no problem.
Nice simple solution if it works.
Feb 22, 2008 | JVC DR-MH30S DVD Recorder
Dubbing to DVD not working
make sure the DVD is formated.
Feb 01, 2008 | JVC SR-DVM70 DVD Recorder
Play dvd on laptop
What type of DVD are you recording with ? -R or +R
Are you recording in Video or VR mode ?
Dec 15, 2007 | JVC DR-MH30S DVD Recorder
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
