Question about Belkin Computers & Internet
I have recently moved house from a virgin broadband connection taking my router and lap top with me. My new home has existing virgin broadband. Having plugged everything in as should be my laptop finds the router, connects with an excellent signal, however it fails to connect to the internet as previously. Does it require recoding, resetting or ? pls help
    Scholar:
  • 45 Answers
Try reseating te broadband connection to the router.
It soundslike your router works if it connects to your laptop with a great signal. But its not sending any information through.
Try reseating. if it does not work. you might need to do a fresh reinstall of the router. Usually the broadband connections attach itself to a mac address of a network card. If you recently put a new router the network cards MAC address is different and it might not send signals through. like for me for cable i have the same issue.
Try this let me know how it does. If any problems please let me know.
I hope this helps
Please Rate.
Posted on Sep 18, 2008
Virgin has installed. D link wireless router (home address) I have 2 laptop xp window vista and pc upstair they detect the vg 50Mb broadband but can not connect ! When I go with my 2 lap top elsewhere I...
1.
Open Network Connections
2.
Right-click Wireless Network Connection, and then click Properties.
3.
On the Wireless Networks tab, do one of the following:
• To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
• To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
• To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
• If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-300 Wireless Router
I have used this router for 2 years inone home attached by cable to a desktop and at the same time set up for wireless for other laptops in the home. I have got a new router for that house, but want to use...
1. Yes, clear the router for the new house.
follow these instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 03, 2010 | D-Link DSL-G604T Wireless Router
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Wireless G Router
the ask4 ISP has the following on their website.
"ask4 broadband works differently from most other broadband providers. With our broadband you do not need a telephone line or a modem, all you need is an Ethernet Enabled computer."
Assuming that this is the case, you need to make sure that your computer and other devices are hidden behind a standard firewall router, that supports NAT. (NAT stands for network address translation)
My other assumption is that by resetting your firewall router to the factory default settings. by and large this will enable a couple of things;
1 it will enable your router to obtain a Dynamic WAN address (this is the port plugged into the wall socket).
2 it will enable your routers inbuilt DHCP server, this will let your computers etc obtain a dynamic IP address + hide them behind your inbuilt firewall.
if you use the wireless option you will need to set this up from scratch, but I guess that you would have done this before. If you need further information check the routers user manual, just go to the manufactures website and search for your model the manual should freely avaliable.
Nov 05, 2008 | Belkin (F5D5231-4) Router
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Jul 23, 2008 | Belkin Computers & Internet
Router help
I just purchased a Lynksis Wireless G router from you guys. I was told that it would help me get great wireless access allover my house(mind you I do not have a very large home) The wireless device is upstairs and works perfect with my home computer, but it does not work well downstairs. Slow and crashes
What do I need to do to make this work?
May 11, 2008 | Linksys EtherFast Cable/DSL Router
Lap tops
just to create a new connection with pass word and
IP address. if needed
Apr 29, 2008 | HP Compaq nc6000 Notebook
Wireless set up for ntl
hey thats easy man dont worry, if you have a existing broadband at home, just connect the broadband to your router, then connect the cable that comes up with the router to your laptop. then access the web configuration of the router, the ip address is usually written in the manual. then configure it with the settings that your Internet Service Provider gave you to connect. then configure the wireless settings and your done... if you still have problems, please feel free to contact me again..........
May 11, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
93 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
