How do you adjust color guns in an rgb projector?
I LEFT MY TV ON AND WENT TO WORK, WHEN I CAME BACK 12 HOURS LATER THE COLORS WERE GONE . NOW I SEE ONLY BLACK AND WHITE.
ITS A SONY 48 INCH PROJECTOR TV.
Posted on Sep 18, 2008
2 Suggested Answers
asnowman
  • 788 Answers
SOURCE: adjust RGB guns double vision
Your symptom sounds like at least one damaged convergence IC.
You are correct you can sometimes rework the solder connections on each of these IC’s, although, if the convergence does not fix itself from time to time, you most likely do not have a bad solder connection. You will have a faulty IC. I recommend to replace them both at the same time because the chips legs can fall off due to the heat of the IC.
Please be sure to remove all of the white heat sink compound on the heat sink and apply a even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I believe that your set has two. They are secured to a very large aluminum heat sink. I think that the IC numbers will be IC8001, 80002.
The IC’s are large and black, you cannot miss them. They will usually have an STKXXX-XXX number on them.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact Hitachi part, or Sanyo, even though the numbers on the front are the same, and they look exactly like the $10,00 ones, they are better and more reliable.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 17, 2009
How do I change from black and white to color
input source :Computer RGB (Digital) and RGB(Analog)
you should select the RGB(Analog)
Video ,select Auto
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 22, 2014 | Sanyo PLC XU35 Multimedia Projector
My PJ506D Viewsonic projector is projecting an image with too much green. How can I adjust this?
You will have to go into the menu system and find the controls for the red, green and blue guns and adjust the red and blue guns to counter the green.
Atypically if this is an older projector and has seen a lot of use you will start to experience the degradation of luminescence in the tubes.
Resolution: If the adjustments do not resolve the color issue, you will need to have one or more guns replaced. The economics of this replacement point to a new projector.
Aug 13, 2009 | ViewSonic PJ506D DLP Projector
Fix my line problem but red LED flashes five times
Hi Guys, Looks like your advise took care of the problem. I adjusted the power knobs for each of the RGB guns on my Sony 51 inch projection TV. The color looks great and I don't seem to have the blinking indicator light bugging me any more. I will be sure to suggest you folks to anyone with these type of technical questions.
GREAT JOB!!
Jan 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
The color on my Epson Powerlite S3 powerpoint projector is very purple; not the true colors at all. I have tried adjusting it using the color, tint, brightness, etc. adjustments but it never gets to the...
Two possible solutions:
1) The video mode is set to Component/RGB instead of VGA.
2) The cable you have may have a break inside of it.
Let me know if you find anything.
-Jeff
Aug 28, 2008 | Epson - PowerLite S1+ Multimedia Projector
Display color problem, Eiki projector LC-NB2UW
Hi sjmuseum
If you cannot find the advanced option in the standard users menu , then it will only be in the Service Menu which you would have to call Eiki support to find out how to enter the Service Menu.
May 12, 2008 | Eiki LC NB2UW Multimedia Projector
Colors displayed
Go to Menu, Advanced, and set the color adjustments to RGB. That should work.
Dec 03, 2007 | Eiki LC NB2UW Multimedia Projector
Green screen in the middle
Check the Fly-Eye lens and the RGB panels.
May 31, 2007 | Sharp Notevision PG-A10S Multimedia...
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
