Windows dvd maker
Everytime i use my dvd maker it stops working and it closes and says windows will close the program and notifiy you if a solution is avalible,can anybody help
  • 1 more comment
  • salisbury Sep 18, 2008
    ask microsoft
  • carlataylor4 Sep 21, 2008
    when i try to burn movies i keep getting a message that says windows dvd maker has stopped working ,windows will close the proogram and notify you if a solution is avalible can anybody help im running vista .
  • avessa316 Apr 19, 2009
    I am having the same problem as above. I ran into a problem when following the steps in the solution. When I got to the renaming file part, vista stepped in a prohibited it. I guess it doesn't see me as an admin even though I am. Any suggestions now?
  • 61 Answers
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Posted on Sep 20, 2008
I'm doing a school essay for tommorow. It's a movie, and I have put many hours and hard work into it. Now, when I want to render it, it stops and says "Sony Vegas Movie Studio 9.0 has stopped...
While its not possible to tell exactly why your program is closing, you should be able to use another movie application, such as Microsoft Windows Live Movie Maker or Videopad, which help you complete your assignment on time. You can download Videopad at:
http://www.nchsoftware.com/videopad/index.html
I hope this response helps you out.
I wish you the very best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 22, 2011 | Sony Vegas Movie Studio for PC
I installed arcsoft photoimpression 5 on a vista and 7 computer. Everytime I load a picture an I get an error message. It reads, "Photoimpression has stopped working. A problem caused the program to stop...
Funny I was using PhotoImpression 3 with no problem on the same machine for 3 years...until today {24-8-2010}. Now when I try to start the program a message appears saying "PhotoImpression has stopped working" with a bit saying that Windows will close the program and notify if a solution is available. I'm using Visa Home Premium. I use it alot and I need it back.
Aug 17, 2010 | Arcsoft PhotoImpression 5
Windows service executable has stopped working
You do not mention this in your post, but you should try using windows update to update your vista service pack.
Jeff
Sep 02, 2009 | Microsoft Windows Vista Home Premium with...
A problem caused theprogram to stop working correctly. Windows wi
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example
Mcafee's free online anti-virus to rule-out a virus problem.
http://us.mcafee.com/root/campaign.asp?cid=45694
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
Jul 11, 2009 | Computers & Internet
Windows dvd maker , vista home premium o/s, hp pavillion laptop
I found the biggest problem with using win dvd maker is when windows asks you to format the disk first. If you do format the disk first then win dvd maker has problems writing to it. Only put the disk in the drive when win dvd maker asks you to other wise you will be taken through to format the disk first and if you choose to cancel that it causes silly problems. If you are trying to make more than one copy of the same disk and win dvd maker is acting up, just do the one copy and then close the program. Then use a program such as nero and make copies from within there. You can insert the disk open Nero and select copy disk, you can do this until you have all of the copies that you need. Personally I found that win dvd maker is too slow and laborious.
Dec 18, 2008 | Computers & Internet
Application crash
hello,
i was trying to login on My BDO Internet Banking and the website is crashing everytime i open it...
here is the application error...
Problem signature:
Application Name: iexplore.exe
Application Version: 7.0.6001.18000
Application Timestamp: 47918f11
Fault Module Name: StackHash_fd00
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 03590cc6
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
can anyone help me please....i appreciate it!!!
Oct 23, 2008 | Yahoo Messenger
Yahoo messenger has stopped working
I have gotten this issue several times being a tech for the HP notebook division and I found a simple solution for it.
Right Click on the Yahoo! Messenger icon on the desktop and select properties.
Click on the Compatibility Mode tab
Check the box at the top to enable it and make sure the mode is Windows XP SP2.
Select ok.
Restart machine.
I hope this works for you all. =)
Acer crystal eye webcam
Hey,
Try taking all your pictures from Windows "my pictures" folder and move them somewhere else. I moved them to another folder and just called it Photos. And all of the sudden my camera worked... I have no idea why!
Hope this helps
Mar 23, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
484 people viewed this question
David Payne
David Payne
