How do I fix a key that fell off of the keyboard of a Gateway notebook, M-6816 please?
    Problem Solver:
  • 5 Answers
You will need a set of fine-jawed needle-nose pliers and a small paperclip half un-bent. Turn off the power to your laptop and remove the battery. Locate the small black plastic cantilever assembly that would otherwise be joining the key to the rest of the board. It should look like an "X" from the side view. The cantilever assembly is very fragile, and may have been damaged in whatever event caused it to detach in the first place. If this is so, you're pretty much beat for the rest of this fix. If it is still attached to the board, carefully remove it by squeezing the inner legs to dislodge the bottom pegs from the retainer clips on the keyboard base. If it is not attached to the board, attach it to the underside of the key in the reverse of the process described supra.
Once done, hold the laptop in such a way as to allow you to see under the key for as long as possible while you do the following:
Grip the properly attached cantilever/key assembly with the pliers by the widest frame of the cantilever assembly, about halfway between the crux and the edge, such that you are gripping the frame perpendicular to the alignment of the outer frame. Squeeze very gently, while attempting to seat the wider frame into the wider-spaced clips on the keyboard. Once done, use the paperclip to hold that frame down to the keyboard (very carefully, as the underlying traces can be easily damaged by anything metal) while simultaneously gripping the narrower frame with the pliers in the same way you did the wider, while attempting to get the peg on the farthest edge of the narrow frame into it's clip. Remove the pliers, and attempt to re-seat the final peg, the one closest to you on the narrower frame, in it's clip using the paperclip.
NOTE: This does not always work. If it doesn't, or if the cantilever clip is damaged irreparably, your sole remedy is replacement of the keyboard unit, which is removable.
Posted on Sep 18, 2008
please be patient and answer the questions.
Is the keyboard typing all by itself or not?
thanks so much
Sep 15, 2012 | Gateway Id47h02u Notebook I5-2410m {intel...
On my HP keyboard, the right side of the 7/&
If the key or key retainer is not broken, then try the steps from below link to fix the keys.
If unable to attach, you need to change the keyboard.
Jul 28, 2010 | HP Pavilion dv8000t Notebook
I am sorry to inform you that this issue is hardware malfunctioning of the keyboard. The laptop keys are inter related to each other. So there is no option to fix the single key for your notebook. You need to change the entire keyboard of the notebook.
Jun 10, 2010 | HP Pavilion dv9000z Notebook
Need to replace my keybroad on my laptop how do I get it done from disassemble to assemble
You could refer a Guide :-
If you want to Fix Buttons :-
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | Gateway CX2724 Notebook
Power Problem with A/C adaptor on my Gateway M-6816. The light on the a/c adaptor flashes green and the laptop wont charge. This is a new factory a/c cord.
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 17, 2009 | Gateway M-6816 PC Notebook
Gateway Notebook enter key came off
It doesn't make any sense trying to repair the keyboard when a key breaks. You should contact Gateway at
and get a replacement keyboard. The replacement is relatively simple and the Gateway support site should help in understanding the steps for replacement.
Sep 07, 2009 | Gateway 2520915 Keyboard
A key from my keyboard just fell off,how do fix it back?
Most keyboards the keys tops just snap into place. However, if the plastic is broken you will probably have to replace the keyboard. Good thing is they are relatively inexpensive.
Aug 24, 2008 | Gateway Computers & Internet
Gateway notebook key fell off keyboard
Unfortunately, there is no instruction out there for this. My advice is to take one of the other key off in order to see how it fits, then put the key back on the same as the other. I suggest a key right next to the one that is off. Be very gentle and try to remove only the key, leaving the retainer.
Jul 16, 2008 | Gateway MX8711 Notebook
Sticky keys
Dear rwertheim
Try the following guide
There are no guides from Gateway for the keys available for the but this guide will be more than enough to help you through this one in order to remove them. Its should be completely the same principle.
Cleaning the keys should be done without alchohol based cleaners because the lettering might be erased. Use some soap and warm water instead and gently scrab with a soft brush the bottom of the keys.
Please remember to take out your laptop battery/ac adaptor in any case since you will be working at hardware level with your equipment.
Regards, and I wish you no more sticky keys!
Please dont forget to rate this solutin!
Apr 02, 2008 | Gateway MX8711 Notebook
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
