Question about Garmin GPS
My Garmin c330 some times operates o.k. then other times I get a low battery warning and soon it shuts off, or it will power up and then a minute or so later it shuts down. It is pluged in and the outlet seems to be fine. What is my problem?
    Scholar:
  • 147 Answers
Check the fuse inside the adapter.
Posted on Sep 18, 2008
After several munutes of on the screen goes to
I have a Garmin Street Pilot c330 which when plugged in and power button pushed, the screen lights up for a few seconds and shuts down. It was giving a low battery warning before shutting down. Where is teh battery in teh unity? and should I replace the fuse?
Apr 22, 2009 | Magellan Maestro 4040 GPS Receiver
My garmin c330 will not run it had said battery low. Even in car lighter it will not stay on. When I push the power button it will power up and shut down right away
The Garmin C330 has an internal Lithum Ion battery that needs to be recharged. Use your USB cable that came with the device to connect it to you computer. The computer of course has to be on. Leave it connected to the computer all day or over night. After that time it should be charged completely. If it is not charged after that time the unit will have to be returned to Garmin to have the battery replaced.
Apr 02, 2009 | Garmin StreetPilot C330 GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Black Screen to no power
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin problems
try contacting garmin they are at garmin.com they should have a dealer near you or take it back to where you bought it they should exchange it no problem as long as you have the reciept hope this helps
Aug 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot c330 problems
my c330 shuts off after 3 seconds and then wont start back up . on battery or adapter
Apr 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Jan 21, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
82 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
