Question about Bosch KGU31124 Bottom Freezer Refrigerator
Bosch KGU31124 Freezer Not Working
Bosch Exxcel FF Fridge Freezer (KGU31124)
This is a frost free fridge freezer. The fridge is still working and when we switch it off & on the freezer section starts to cool then stops (within 5 minutes). The warning light to say that the freezer is not warm enough stays on.
Can anyone help to say where or what the problem is. This appliance is three years old. We have switched the whole thing off for 12 hours, cleaned it, checked for any blockages (Only one place in the fridge) but it has made no difference.
Fridge is working fine. Freezer is not working at all. Any ideas or help would be much appreciated.
Thank you
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Posted on May 23, 2011
How to take doors off Bosch Exxcel KGH39A07GB
I've just had to do this - a real pain, and you would think that Bosch would include it in the instructions or somewhere on their website!
You have to put the fridge/freezer on its back (putting a cushion or something like that at the top to make sure the back doesn't get damanged). Starting at the bottom, unscrew the three bolts holding the bottom door in place, then the middle hinge between the fridge and freezer, and then the screws at the top holding the fridge door in place. Then reverse everything round (you may have to make holes where there are dimples on the top of the freezer door/bottom of the fridge door). Good luck!
Sep 19, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Hi can you tell me what the red explanation mark on my bosch exxcel frost free version fridge means please. mike
it has a problem and its telling you this,,,most likely its to warm inside of it this could be the thermostat playing up
Jul 04, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Jan 07, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch KGU31124 Bottom Freezer Refrigerator Logo
456 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
