Dvd rw my notebook is showing a error code 39 on my dvdrw .... how do i fix that Pleases help
    Sergeant:
  • 320 Answers
Please go through the below provide steps.
Fixing Code 39 Error
If your CD-ROM drive is not visible in My Computer, you may see the following error message displayed with the CD or DVD drive item in your Device Manager. (Steps to open Device Manager are discussed later in the article.)
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
Using Registry Editor
If updating the driver does not resolve the problem, it indicates that there is a problem in the registry. To fix this problem, you may have to remove a few keys from the registry.
Note: Be careful while working with the registry editor because changes done to the registry using the Registry Editor are irreversible and mistakes can leave you with more problems than when you started. Therefore, it is recommended that you make a backup of the registry before proceeding with the changes.
After you have removed the registry keys listed below, you will have to reinstall all applications that you use for CD or DVD recording to make them work properly.
To fix the error by editing the registry, perform the following steps:
  1. Exit and close all applications currently running on your PC.
  2. On Start > Run type Regedit and press the Enter key.
  3. Next, navigate to the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. Delete any of the following registry entries if they exist under this key:
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
  5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
  7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Thank you........
Posted on Sep 18, 2008
Won't burn DVD data discs, error code 0x207
Have you looked at this from ACER: http://acer--uk.custhelp.com/app/answers/detail/a_id/3410/~/error-code-0x207-shows-during-recovery-dvd-creation I'm sure you already know it seems to be a common problem. Every post seems to point to Media type , can't use RW disk, +or-, seems kink of finicky which seems odd. Only use DVD+R or DVD-R.
Apr 02, 2013 | Acer Aspire 53362524 Intel Celeron 900 2....
Dvr writing
Did it work in the past? Are you sure your system can write DvD's? Click Start/My Computer and look at the description of the DvD Drive. Does it say DvD-RW or DvDrw which means it can write a DvD? Look on the side of the laptop at the dvd drive, does it say DvDrw or DvD-RW or DvD Rewritable? If so that means it is capable of writing Dvd's.
If it says just DvD or DvD Rom that means it can only read dvd's.
Make sure the dvd you put in the drive is blank. I've been on many service calls where they said the dvd was not writing and found out that the media was not blank.
May 30, 2012 | HP Compaq Presario V2000 Notebook
Dvd driver does not play or burn blank dvds compaq r4000 but it will play dvds & cd its got dvdrw/r rw dvd+r dl n the driver
Try another DVD-RW drive because it sounds like the laser is going bad. Burning requires alot of power from the laser. Playing DVD or playing cd's doesn't require much so thats why it would play those.
Feb 06, 2012 | HP Compaq Presario R4000 Notebook
Is it possible that a cdrw/dvd of Toshiba Tecra M1 be replaced with a dvdrw?
Yes, it is possible to replace CD, DVD with DVD+RW on Tecra M1. Generally, it is possible to upgrade optical drive on almost all the laptops.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 27, 2011 | Toshiba Tecra M1 Notebook
HP pavillion DV6500 CD/DVD RW not responding, unit will try to boot up many times when system is starting but when I put in a CD or DVD no response and doesn't show a drive in My Computer. I've opened up...
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
If not than use Philip Screw Driver take out optical drive and put it back in Reinstall CD/DVD Drive drivers using Device Manager .
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 08, 2009 | HP Pavilion dv6000z Notebook
My dvd drive are not sense by my laptop. Show drives may be corrupted or missing (code 39). My driver is pioneer dvdrw-dvr-k17bata.
Try uninstalling through the device manager. Once uninstalled reboot and see if the drive is recognized and software/drivers install automatically. This should fix the problem. Hope this helps.
Sep 30, 2009 | Pioneer DVR-107D DVD±RW Burner
DVD ROM/DVDRW
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Mar 28, 2009 | Microsoft Windows XP Home Edition
I cannot format DVD-RW
I had to download the latest firmware (rev. VS0M) for Lite-On DVDRW SOHW-832S. This fixed the problem.
Jun 21, 2008 | Roxio Easy Media Creator 7
Computers & Internet Logo
279 people viewed this question
David Payne
David Payne
