Question about Nikon Cameras
I have a Nikon D40X wiht a small lens, I think it's 18-70mm. But I would like a lense that would be able to zoom a bit further.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Then do so. I personally like the 70-300 VR.
Posted on Dec 30, 2009
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
Apr 14, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
Please recommend digital SLR nikon cacmera for this lens
Any Nikon digital SLR will work with this lens. However, there are two things to consider.
On cameras other than the D700 and the D3 family, the smaller sensor will make the lens appear as a 105-315mm. On the D40, D40x, D60, D3000, D3100, and D5000 cameras, you will lose the autofocus capability.
Oct 18, 2010 | Nikon AF 70-210mm f/4-5.6D Zoom-Nikkor...
There is a small black tube like piece that has come loose inside my lense and I need instructions on how to disassemble. It has something to do with the zoom I think?? Nikkor 18-55 ED
The small black tube piece is a sliding light baffle which has come loose. Zoom lenses are very complicated to disassemble, and you have to have both the knowledge, experience, and the right tools to disassemble a zoom lens.
The tube should never have come loose in the first place, so I would classify this as a product defect. Contact Nikon, fully describe the problem, and insist that they repair the lens at no charge (although you will have to pay to ship the lens to their repair center).
Apr 26, 2009 | Kodak Pronea 24-70mm IX Nikkor Lens
I have a new D40x Nikon. Im trying to use it in manual mode however I can't set the F/number lower than F4.8 is this normal?
What lense are you using? you will not be able to set it lower than the minimum aperture of your lens, assuming it is the 18-55 which has a variable minimum aperture, it is 3.5-5.6 depending on where you have it set, at 18mm it will be 3.5 and as you zoom out it will raise to 5.6.
Dec 03, 2008 | Nikon D40x Digital Camera
Problem with the Nikkor AF-S DX 55-200 zoom lens.
I just had the same exact problem! However, in my case I was finishing up a photo shoot at work, went to switch lenses, and when I picked up my 55-200mm zoom lens, the tip of it fell off!! I was able to put it back into the end of the lens, but now I am having the same autofocus problem and sound effect. I think it is because it is off track inside the lens. But I have only had mine for 5 months! I'm preparing to send it to Nikon for warrenty repair.
Apr 13, 2008 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
D40x Camera with mirror lens = black pictures
Usually tele lenses need longer exposure,and mirror lenses need more than normal lenses.Try with 1sec, half sec,( 2 in the speed dial, not 2" ) or quarter sec (4 in the speed dial) exposures.
One more thing, you need good sturdy stands to hold cameras.
Apr 02, 2008 | Nikon D40x Digital Camera
D40X Telephoto Lens Lock
This has happened to me on two occasions with two different 18-55 lenses. I would call this behavior "common".
Problem: Inside, there are three "rails" that the twist/turn elements of the lens slide up and down on. On the back of each of these rails is a friction material (glued on). Sometimes this will come loose and start to catch as the lens is zoomed in/out. When the lens locks completely, the sliding mechanisms have become derailed or have gone askew sideways and are being forced in a way that prevents movement (hard to explain without your opening the lens and seeing for yourself).
I have attempted repair of my lens by dismantling it, making the repair, and reassembling. I do NOT recommend this! (many small parts that can break easily). Mine worked for a time but was ruined by my inexperience.
DO NOT FORCE THE LENS or you WILL damage it permanently.You should send it in to a qualified technician for repair. I know this may not be the answer you wanted, but it's not worth trying yourself and ruining unless you plan to buy a new one anyway.
Mar 31, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens slow to focus and makes a bad grinding sound
It sounds like a lens problem, not the body's. Have you tried it with another lens? If you don't own any lenses, go to a camera store and ask to try out one of their lenses, if the problem goes away then you know what is causing it. The lenses usually have 5 year warranty.
P.S. You should consider the option of buying another lens for the baseball games that has high zoom and VR.
Mar 15, 2008 | Nikon D40x Digital Camera
Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5) Non-CPU: Can be used in mode M, but exposure meter does not function; electronic range finder can be used if maximum aperture is f/5.6 or faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
Feb 01, 2008 | Cameras
Cameras Logo
21 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
